FPV @ RDMFC
FPV @ RDMFC
FPV flight at the field 27.5.14 including tree clip and crash after I lost radio RX, note to self dont fly low level behind the hedge while sitting down!
3 flights after this the quad started behaving strangely, upon landing it seems I had a broken arm, It must of cracked in this crash and got worse as the flights went on
anyway here it is (when its finished processing watch in HD)
Re: FPV @ RDMFC
3rd flight after the crash, quad got all nervous, but it down to the wind but on landing found I had a broken arm probably from the above crash.
Thanks to Pete Squire for his help tonight good crack
Re: FPV @ RDMFC
Looking at the crash in the first vid, the motors cut at 4.13. At that moment, and for several seconds before that, the image shows the quad as being above the hedge and looks like most of our field is visible. If so you would have had line of sight for the radio signal. Might be worth looking for range or aerial problems
Re: FPV @ RDMFC
Agree with that Alan but I do have a habit of holding my TX facing the floor which won't help and both rx and satellite would be blanked by vtx 2 motors and 2 ECS at the point of fail, I've been much further away than that but with more hight with no props both on this quad and others inc fixed wing
Re: FPV @ RDMFC
Could also be another doggy solder joint in a lipo, I will obviously be checking all options.
Re: FPV @ RDMFC
change the way you hold transmitter it's a gay look anyway with spread legs
Re: FPV @ RDMFC
Re: FPV @ RDMFC
its on your avatar
the mouth looks tricky
Re: FPV @ RDMFC
nob
