Moday 25th
RDMFC :: Field Tales
Moday 25th
Not long back from the field, put four more flights on the Sbach today, I think I've got it trimmed out but need to fly it on a calmer day just to confirm. I was going to stay later but got cold and tired of my own company so came home for some nosh. Forecast looks better for tomorrow, live in Hope die in Caergwrle
Re: Moday 25th
You were just leaving as I passed from work.
I stayed at home last night to sort the Raven Canopy, It seems the Ply tounges at the frount of the canopy have warn. this is causing the front to lift thus removing the canopy. Ive added 2 Carbon tubes to the front. Hoppfully this will cure it.
Re: Moday 25th
Mark/Bri what was the name of the model shops that i can pick up the stuff i need for my Sbach , fuel tank , electrics and stuff ? what size nicad for the ignition (pen cell 2500 or subc ) what is the thing called that you use when usin a lipo for RX power thanks lads
Re: Moday 25th
Gaz your Sbach should come with a tank but the bungs are usually a bit suss. If you're going with lipos and none high voltage servos you'll need a voltage regulator down to 6V, if you shop around you can get these complete with a fail safe switch ie if the switch should fail it will fail "ON". AS for the ignition 4 cell 2500 AA's will be fine. Mark will probably point you towards the shop/s
Re: Moday 25th
Here's a reg that will fit the bill http://alshobbies.com/shop/lookupstock.php?pc=7628
Re: Moday 25th
As Bri says all off the self stuff,
I would get ING pack from http://www.component-shop.co.uk or if you cant be arsed charging like myself pay abit more and get Eneloop from Overlander.
Reg: The one Bri has pointed out is great or I use http://www.vanderbuiltmodels.co.uk/8-15-amp-reg-625-p.asp
Servos proberbly Al's or Leeds Model shop the cheepest, maybe Webbies worth a look to.
Rest of the gear from Vanderbuilt or IAD
