Blimey, it's got a drink problem! Empty2024-07-30, 08:27 by Daniel Gillespie
Blimey, it's got a drink problem! Empty2024-07-17, 09:55 by Daniel Gillespie
Blimey, it's got a drink problem! Empty2019-07-12, 18:53 by Rich
Blimey, it's got a drink problem! Empty2019-04-14, 15:36 by Roy
Blimey, it's got a drink problem! Empty2019-04-13, 16:49 by Roy
Blimey, it's got a drink problem! Empty Blimey, it's got a drink problem!
Post by Andy Sayle 2009-04-30, 23:35
This little turbine of mine doesn't half drink some fuel! it burns its way through 2 litres of kerosene in about 10 minutes or so, and has rpaidly depleted my supply of B&Q's finest filtered paraffin!
Just a quick question anyway, and I did ask this down at the field last weekend but my memory was addled from the fumes, does anyone know a cheap place to buy paraffin from by the litre? B&Q charge about 5 notes for 4.5 litres, so anything less than one of our finest English UK Pound coins per liter would be good Smile
Blimey, it's got a drink problem! Empty Re: Blimey, it's got a drink problem!
Post by Guest 2009-05-01, 01:15
thers a heating oils place on the htm in rhuddlan andy.
Post by Mark Barnes 2009-05-01, 08:25
theres a garage in Hollywell Nath uses its about 96p a litter
Blimey, it's got a drink problem! Empty paraffin
Post by Guest 2009-05-01, 08:32
message deleted
Post by Andy Sayle 2009-05-01, 09:10
HTM is the first port of call methinks, nice and easy to get to Smile Thanks for the other sources too, being a bit of a cheapskate, I'll end up going for the cheapest after considering how much it costs to get there!
Blimey, it's got a drink problem! Empty Paraffin
Post by Guest 2009-05-01, 12:05
Correction
Paraffin (Not Kerosene but lamp oil) price at Esso Talacre (Lobitos) about 90p per litre.
Post by Andy Sayle 2009-05-01, 12:11
Paraffin/Kerosene is pretty much the same stuff. Jet A1 fuel is basically the same, just loaded with other gubbins to help prevent waxing, icing and algae. Most of the chemicals added to make Jet A1 are nasty stuff really. Plus Jet 1A absolutely STINKS!
Turbines will burn pretty much any fuel from Diesel, to Paraffin, to powdered coal dust, to gas. The little ones are usually designed to run on paraffin/Kerosene (mine is), as it is commonly available in a number of formats. Before I use any fuel, it is filtered before mixing in about 5% turbine oil (or high grade 2 stroke oil), then filtered again on it's way into my fuel station. It gets filtered again on it's way out and into the model, and again before the fuel pump. There is one last filter before the engine too Smile
Post by Guest 2009-05-01, 12:14
Andy you can get your Jet oil from Hawarden airfiled. It's alot cheaper than from the model jet suppliers. I haven't bought any for some time as I purchased a crate, it was that cheap. 2 litres of kerosene would last me 8 minutes max.
