35 mhz Receiver
35 mhz Receiver
35 mhz receiver
Having fun with receivers again fitted new one today and it works well untill I get 4 feet away and it stops receiving from the trany does it need tuning in or throwing in the bin it is Futaba, I don't now much about receiver and tranys can anybody help.
Re: 35 mhz Receiver
Very likely it's the aerial of reciever, possibly broken - you can check it with a multimeter - set to Ohms/continuity and measure between end of the aerial and soldering point inside the RX. - easy to fix if that's the problem.
While checking the aerial - move it arround .
Also you can check the tranny with a different (100% working rx) and also check the rx with different tranny.
Re: 35 mhz Receiver
Have you got the right crystal in for the job ie single or dual conversion, mind if it's wrong I don't think you would get anything at all. It does sound likely to be a duff receiver
