Nieuport 17 Empty2024-07-30, 08:27 by Daniel Gillespie
Nieuport 17 Empty2024-07-17, 09:55 by Daniel Gillespie
Nieuport 17 Empty2019-07-12, 18:53 by Rich
Nieuport 17 Empty2019-04-14, 15:36 by Roy
Nieuport 17 Empty2019-04-13, 16:49 by Roy
Nieuport 17
+6
Peter Squire
George Robson
10 posters
Nieuport 17 Empty Nieuport 17
Post by George Robson 2010-10-05, 17:08
Nieuport 17 Modnie10
Nieuport 17 Modnie11
Nieuport 17 Modnie12
George Robson
RDMFC Bonus points : 33
Nieuport 17 Empty Re: Nieuport 17
Post by Mark Barnes 2010-10-05, 18:54
Ive uploaded them for you George, You need to use the [img] code thats under the pic in your photoshop album then copy and paste direct into the forum post. It looks like you were using the image tab on the post screen (i think) anyway
Cracking looking model give us the specs
Post by Brian Colclough 2010-10-05, 19:01
Very nice George Cool Has it flown yet Question
Post by Guest 2010-10-05, 19:49
looks really good
Post by Peter Squire 2010-10-05, 20:33
Looks really nice George
Peter
Peter Squire
Peter Squire
RDMFC Bonus points : 413
Post by George Robson 2010-10-05, 20:44
First of all many thanks to Mark for putting the images on the forum. Some of the details are as follows :-
The model is scratch built in the original sense ie. the plans were drawn from three views and photographs. There were several reasons for this,most kits are inaccurate in various ways, thick wing sections, longer nose for balance etc, the final reason, I like drawing plans.
The model is 82" span (none of this metric nonesense) Weighs about 13lbs giving a wing loading of approx 23 oz/sq ft. Sadly it is not electric powered, but by a Zenoah 26 with a 20*6 prop.
It is constructed from conventional materials ie balsa, spruce, ply, (may be these are not conventional these days) it is covered in silver solar tex with hand painted roundels etc.
The model has not flown, I am hoping for lots of moral support on its first flight. The first flight is when I will find out the reason for the longer noses and the none scale wing section.
George Robson
Post by Brian Colclough 2010-10-05, 20:50
Look forward to seeing it fly George, I'm sure we can muster some support but whether it will be moral or not is another matter. With the short nose have you struggled with the C/G?
Post by Allan Patrick 2010-10-05, 21:19
Very well done!
Post by Marty 2010-10-05, 21:43
Beautiful model of a beautiful plane! well done cheers
Post by Rich 2010-10-05, 21:45
If I wore a hat I'd take it off, I'll give you plenty of support if you weren't cack handed I help you fly it as well
RDMFC Bonus points : 5694
Post by John Bow 2010-10-05, 21:58
One of my favourite aircraft, well done George.
I would love to be there to photograph the first flight, please give me a ring if you are able.
Regards
John
John Bow
RDMFC Bonus points : 25
Post by melfyn 2010-10-06, 13:37
Nicely done George, look forward to seeing it in the air. There are very few WW1 models in the club so it will make a change to see something different at the field.
Like Brian I wonder if the C of G was a nightmare or was the Zenoah heavy enough to balance it?
Post by George Robson 2010-10-06, 14:36
The biggest problem was finding where the C of G should be. The aeroplane is a sesqiplane with both wings swept back, which enables the
C of G position to be further back, however using available formulae I worked out a position, in the end I cheated and looked at various existing plans and used their C of G position. The calculated one and the copied ones came quite close.
The Zenoah is indeed a heavy engine, together with twin Rx batteries on the firewall the C of G came out at the right position ( I hope ).
George Robson
Post by phil barrow 2011-03-18, 12:35
Beautiful Aircraft George
love to see it fly
Phil
phil barrow
RDMFC Bonus points : 114
