Which charge lead?
Which charge lead?
In order to make the most of my time at the sports centre I am after a multi lead charger to charge 6 lipos, 250mah. I've seen a couple on ebay and hobby king but I'm not sure which 1 I need can you guys tell me what you use
soane- Posts : 49
RDMFC Bonus points : 71
Re: Which charge lead?
What lipos are they, what connections do they have and what heli is it for. There is a huge choi0ce on charge leads so this info will help us pic the right one for you
Ta
Ta
As mark says there's loads of ways to parallel charge.
This is how I charge my 2s blade 130x packs.
For most other packs I use this.
They are for an mCPX, I'm not too sure what the connectors are called but the cells are 250mah
soane- Posts : 49
Mr Moff wrote:Is this of any use?
http://www.fast-lad.co.uk/store/xtreme_productions_charging_cable_3pcs_mcpx_lipo_ea-057-b-p-19463.html
Not posted for a while, but logged on today...
Thats the lead I use It works for MCPX fine.
It is a serial lead so you have to charge 3 battery's at the same time.
The lipo charger has to be set to Balance charge at 3 cell charge rate
(The 3 mcpx battery's connected together via this lead turn is into one 3 cell battery (11.1volt)
Neil
Neil- Posts : 88
RDMFC Bonus points : 120
Right at home now so I can use the laptop and type properly! Just ordered that lead from Fast Lad so should be here Friday so I can get them ready for Saturday. The batteries are Intellect 1S 250mAh 25c, so three of them will charge at 750mAh or .7a, at 1c? I'm using Overlander RC6S charger which should be more than capable of charging these.
soane- Posts : 49
If you connect battery's in parallel..the capacity increases (250+250+250 becomes a 1cell 750mah) so 1c = 750mah
If you connect is series the voltage increases and the capacity stays the same (250+250+250 becomes a 3cell with a 250mah capacity) so 1c = 250mah at 3cell charge rate.
Saying that on sat.. I charged my batts at 3c and all where ok. Some batts can handle upto 12c like thunder power.. I dont now how this will effect the life of battery.
If I am wrong some body correct me.
Neil
Neil
Neil- Posts : 88
...so my charge rate would be 0.3a? At 3c that would go to 0.9a?
soane- Posts : 49
That's a posh looking multi charging board your using Danny.
Yep thats my understanding.
The standard mcpx charger charges 1cell if I remember.. at 0.7 so you should be fine at 0.9 for all three on that lead.
But just ask one of the lads on sat. As nearly all have had more experience with lipo's than me but..its worked for me fine...
Neil
Neil
Neil- Posts : 88
melfyn wrote:That's a posh looking multi charging board your using Danny.
I was looking at the posh 6 THUNDER POWER BATTERYS...
Neil- Posts : 88
I've been really abusing those thunder power packs.
Well when I say abusing I've been charging at 10c, not gone up to the rated 12c just in case.
At 10c they charge in around 10 mins for 6 in parallel. Good packs so far.
When weather gets better. I.e 2 weeks in june. I might treat my self to a couple for the 450. And could be on a constant cycle until I dirt nap the heli.... prob 4 flights lol
Ive heard lots of good about the Thunder power bats... and life cycle supposed to be second to none..
Neil- Posts : 88
