» Wanted HS85MG or Similar Spec X4
Yesterday at 3:22 pm by Andyedmead
» July full weekend
Wed Jun 20, 2018 9:08 pm by andy-kaz
» Weston 2018
Wed Jun 20, 2018 12:58 pm by BoLt
» Weston Park 2018
Tue Jun 19, 2018 7:59 pm by BoLt
» tics on the orme
Mon Jun 11, 2018 8:28 pm by BoLt
Landinggggggg
Comments: 6
Drilling a prop
Drilling a prop
Post by Andy Sayle on Tue Jun 22, 2010 3:08 pm
Afternoon all.
I picked up a prop or two at Weston park over the weekend, and I need to drill a set of holes to suit the dle 55. That is no problem, but could anyone tell me what angle the prop should be set at in relation to TDC? I'm assuming it needs to be about vertical with the engine set at TDC....
RDMFC Bonus points : -487569796
Re: Drilling a prop
Post by Rich on Tue Jun 22, 2010 3:17 pm
If you set the bolt pattern at 12, 3, 6 & 9 o'clock then it will be right put the prop at 12, 6 o'clock on compression
RDMFC Bonus points : 5586
Re: Drilling a prop
Post by Andy Sayle on Wed Jun 23, 2010 8:28 am
Cheers Rich.
I gave the prop a good drilling, followed by a good reaming too. It's all balanced and installed, and the SU26 is almost ready for an engine run Smile Just need to sort out the batteries and switch now, and we are ready to go.... Methinks I'll bring it for an airing on Thursday....
Re: Drilling a prop
Post by Zaidy on Wed Jun 23, 2010 8:57 am
As you already mentioned Andy preparation of a prop is very important and the fact that you took your time giving it a good drilling and a good reaming will give you endless hours of fun. Suspect
RDMFC Bonus points : 1827
http://Seahawkap.com
Re: Drilling a prop
Post by Andy Sayle on Wed Jun 23, 2010 9:01 am
Indeed. I did find that it all happened a bit quickly though, so on the next one, I shall take my time, and savour the moment.
Re: Drilling a prop
Post by Zaidy on Wed Jun 23, 2010 9:03 am
Timing is not the issue Andy, its the good reaming that usually makes up for the short fall !
Re: Drilling a prop
