» LLanfair TH Village Fete Saturday 28th July 1030
Mon Jul 16, 2018 8:11 am by Mark Barnes
» SC engines?
Sun Jul 15, 2018 6:07 pm by Gary M Jones
» Saturday 14th/Sunday all nighter
Sat Jul 14, 2018 9:18 pm by Gary M Jones
» sunday 8th
Sun Jul 08, 2018 10:48 pm by andy-kaz
» Saturday 7/7/18
Sun Jul 08, 2018 8:38 am by andy-kaz
How would I balance a prop?
Post by Sam Thomas on Sat Apr 17, 2010 8:02 pm
How would I do it?
Do I need a special tool?
Sam Thomas
RDMFC Bonus points : 1962
Re: How would I balance a prop?
Post by Rich on Sat Apr 17, 2010 8:27 pm
yes it's called a prop balancer
something like this
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=7702
RDMFC Bonus points : 5595
Post by Sam Thomas on Sat Apr 17, 2010 10:28 pm
Ok
So how would I add/remove weight from a prop?
Add lead?
Sam Thomas
Post by Tim on Sat Apr 17, 2010 10:43 pm
Errr, no, If the prop requires lead to get it to balance then take it back to whoever sold it to you!
normally a couple of coats of varnish or similar on the light blade should suffice.
RDMFC Bonus points : 3233
Post by Guest on Sat Apr 17, 2010 11:38 pm
I must say that I have never balanced or felt the need to balance a prop on a fixed wing model. Wooden helicopter blades need balancing but the carbon ones come matched to within a gram so you can just fit and fly.
Post by Mark Barnes on Sun Apr 18, 2010 7:54 am
Sam Thomas wrote:Ok
Add lead?
Give the trailing edge of the heavy blade a light sand
RDMFC Bonus points : 8225
Post by Tim on Sun Apr 18, 2010 9:27 am
Props should always be balanced, and the recommended method by many is to add to the light blade rather than remove material form the heavy one- however, I confess to occasionally doing as Mark does, except when he is driving.
Post by Mark Barnes on Sun Apr 18, 2010 10:29 am
Intersting, i dont think ive ever added, i always remove
Post by Andy Sayle on Sun Apr 18, 2010 10:51 am
On the resin based electric props, it is sometimes incredibly difficult to get lacquer and paint to stick to the blades in order to add weight to the light blade. It is far easier to sand the trailing edge of the heavy blade.
RDMFC Bonus points : -487569795
Post by Brian Colclough on Sun Apr 18, 2010 11:40 am
I've always done it with either paint or clear lacquer, never resorted to violence, yet pirat
Post by Allan Patrick on Sun Apr 18, 2010 8:50 pm
Sam, It is very important to balance props properly whether IC or leccy. An imbalanced prop causes vibration, which can be a real killer to models. An expensive balancer is not required, just the axle part of the balancer shown in the HC link Rich posted y'day is fine if used carefully and these can be picked up for a couple of quid or so. Even a drill bit can be used at a pinch but that is not recommended.
To balance the prop, first is it wood or plastic? If wood then the lighter blade can have weight added to it by a coat of lacquer or varnish. Recheck after each coat and sand back if too much weight has been added. Before the first coat give a light sand so the varnish has something to key to and ensure there's no trace of oil! Several tries with drying time are likely to be needed to get it spot on
If plastic then with some fine sandpaper gently sand the back of the heavy blade over most of its area but not at the hub or tip. Ensure you don't change the airfoil shape. No more than a very small amount of material should need to be removed. While at it this is a good opportunity to remove any mould flash from the both LEs and TEs of the prop
All this assumes there was no damage to the prop before hand and that it was reasonably in balance before starting. If the prop is wildly out or damaged discard it!
RDMFC Bonus points : 1834
Post by Sam Thomas on Sun Apr 18, 2010 8:53 pm
ok
Well my grandad is off to florida and I can get him to get me a prop balancer, and a master airscrew 11x6 plastic prop
Sam Thomas
