Servos for JP Bullet 2
I have just finished "building" a JP Bullet 2 Foam glider and am about to install the radio gear. I was going to use a couple of Hitec HS311 servos, standard size. Servo installation involves digging out the foam and sticking them in. I am thinking about using a couple of Giant Cod's DYS207's mini servos instead as it would mean a much smaller excavation! The torque on the Hitecs is about 3.0kg/cm as opposed to 2.3kg/cm for the DYS'. Would the smaller servos cope with the loading of the Bullet? Does anyone have any experiance of this installation?
Thanks in anticipation!
Steveh
Steveh
Re: Servos for JP Bullet 2
the minis will have the power, however the gear train will be far more delicate than a standard size servo. so id stay with the standards especially as epp slopers arent quite so weight crucial.
Good way to cut slots for servos is to use soldering pistol with coper wire bent into a square - far more precise than digging just - needs some practice cuts on a spare bit
As the guys have both said, servos will be ok just weak fon the inevitalbe bump, and dont just hack away do it with your soldering iron in a well ventelated place as melting foam isnt nice
Hope we have helped
Hope we have helped
JP Bullit Servos
Thanks for that info lads, all taken on board, I'll go and dig out the soldering gun!
Steve
Steve
