Depron foam locally
Re: Depron foam locally
Steve Web sells it in 2 and 3mm sheets. Have a look at his web site.
John, Depron foam that is used for modelling, is usually intended for the floor, literally. It is used as an insulator under laminate flooring. You should be able to get it from a good flooring supplier, although it will be in bulk packs, not single sheets. The last time I looked it was about £50 for 20 sheets of 6mm stuff, or 40 sheets of 3mm stuff (Each sheet is 1 sq. metre, 1.25x0.. Expensive, but if you can get a few people interested, the cost is waaaay cheaper than buying it through a modelling outlet....
Hope that helps.
Hope that helps.
thanks guys for answers.Again the Forum is being used as it should,to help.
p.s. anybody want to buy 39 sheets of 3mm Depron
Last edited by johnoxleydean on 2009-11-11, 10:38; edited 1 time in total (Reason for editing : added comment)
I'd have a handful of sheets too
