ASP 108A Engine
ASP 108A Engine
Just bought an asp108a engine secondhand but never used.Problem..the Carb ,still in plastic packet is for asp91 and under.It does fit but it is for rear needle use,Question,could I use this Carb with rear needle even though Just Engines advertize the 108 as not having one and no parts to fit one.What would stop it from working ?
Re: ASP 108A Engine
John providing you have the remote needle assembly as well as the carb itself I would give it a try you will probably find that being for a slightly smaller motor you will have to open the needle more than the customary 2-3 turns. If it does'nt perform ok you've lost nothing.
asp108a engines
Brian thanks for info... I did e-mail the guy I bought it from He says he sent me the wrong Carb and the right one is in the Post.
Another senior moment,Im having about 3 a week john
