receiver modulation
receiver modulation
Ive a NER-549X 35 MHz no details on the front anybody know offhand what the modulation is ?
reason for asking I do not seem able to get it working,on PPM ,SC,, or Z.... modulation
Re: receiver modulation
Are you sure it has the correct crystal in?
NER-549 is an FM receiver single conversion. This version doesn' t do PCM.
here is the manual which also describes the receiver.
http://www.macgregor.co.uk/support/radio/XP3810-1.pdf
Receiver will work with any Futaba or JR crystal
best to use JR, it fits better with it's crystal holder.
If you use a JR Tx you MUST fit a JR crystal in the Tx
If you use a JR Tx crystal in any other make of Tx. That Tx won't work correctly.
(The JR Tx RF section crystals are cut differently. A peculiarity of all JR gear)
Obviously, you must use matching frequencies in Tx and Rx.
And of course you should use your club allocated 35 MHz frequency
(A mine of useless information from the past !)
I was thinking more about single /dual conversion crystal selection
Brian Colclough wrote:RDMFC has never allocated frequencies Paul
Strange that Brian. When I joined in 2004/5, I was allocated "64". and there were 3 others sharing that channel.
Obviously, many have gone 100% to 2.4G. So maybe no need to assign 35 MHz frequencies.
Perhaps the Committee can advise please what the real situation is now.
thanks guys for your comments.Appreciate it.
Dont understand how the committee can comunicate with my Tx telling it which frequency Im on
We did allocate several years ago, because if you bought a transmitter from a loca source they tended to give out the same channel, as far as I can remember this has now ceased, if you could check the club code of conduct (rules) I don't think it's in there from memory
noticed that the Tx frequency when not in ppm/pcm/s,z mode is 53/72 MHz.The Rx is 35 MHz
To my recollection the committee produced a list of who was on what so that a new member could make an informed choice as to what crystals to buy/select (ie least used frequencies). When I hear a club allocates frequencies I take it to mean they allocate you that frequency and that is the one you "must" fly on at their field. Sorry John this is not helping with your problem
Brian
In 2005, I was told, once allocated, I must always use 64, so I did.
Glad your knowledge of past club procedure highlighted the issue for me.
thank you.
John
53/72 MHz ???
Check your Tx plug in module (back of set)
Sounds like you have a "Made for USA" version in your set
The UK version will say 35 MHz
You may need to get one of these from an old set
PPM, PCM 'S', or 'Z' signals are created within the JR transmitter. This information is then sent out through the plug in transmitter module on 35 ,53 , 72 MHz, depending on which module you fit.
Allocated frequencies
The club used to check the 35 meg transmitters each AGM for channel frequency really transmitted. Not happened for a year or two.
thank you.
John
53/72 MHz ???
Last edited by PDQ on 2010-06-09, 09:36; edited 1 time in total (Reason for editing : more info)
During my time at the club no one has ever told me what frequency I must fly on (perhaps RT tried and failed) and I've never heard of this from anyone else. When on 35Mhz I used mainly 68 but changed crystals on many occasions for different events at the field. I think not 100% certain Colin Little is the man with the equipment if you wish to get your 35Mhz trannie checked, I'm sure a committee member will confirm or otherwise
I now have the TX frequency checkers for 35Mhz in my posession, however as moast members are now on 2.4Ghz the need to use them will eventually cease. If any member needs a 35Mhz TX checking I will bring said equipment to the field the next time I go flying.
anybody want to buy a 35 mhz Rx perfect working order with the right Tx
How much?johnoxleydean wrote:anybody want to buy a 35 mhz Rx perfect working order with the right Tx
im 100% 2.4ghz But I do have some 35meg stuff lying around from john
Im slowly going over to 2.4We have a 6i @2.4 and the JR 35 meg
Paul if you really want it its yours no charge hate to rob a pensioner
What do you mean pensioner ! You're young as me. Anyway, thank you, yes please. I can give you in return some Vapor Lipo's and some other indoor bits.johnoxleydean wrote:Im slowly going over to 2.4We have a 6i @2.4 and the JR 35 meg
I still have all my 35 meg gear and it still works OK. I suppose they are antiques but so am I.
I did invest in a DX7 with 2 receivers and a DM9 module to suit one of the JR3810 tranies.
The DX7 Tx disapointed me in that it it didn't do :-
Easily unplug the battery for external charging
Glider mode
Copying program from 1 Tx memory to another Tx or JR backup on PC
Switching between modes. You have to buy it in the mode U need. 1 or 2
Otherwise it seems OK
Maybe we can liaise with PM's about the swap
Not wishing to divert the thread ( but its answered now really anyway aint it ) but can I ask you a few things about the DX7 remarks Paul.
1) The battery unplugs quite easily actually - and why do you want to anyway? I charge mine in situ ( even Lipo ) attended at 1.5A
2) Mine does all of my ( albeit fairly simple ) gliders fine. With 2 fixed and 6 free mixes almost anything can be donewith some fiddling.
3) Agreed...but seldom really needed surely?
4) No big deal, I dont intend switching modes so whats the problem?
Not being a smartarse, just curious
Sam Thomas wrote:Dont you usualy buy the mode you want anyways...?
Well, in the past "NO".
The DX7 is the first outfit I ever bought where I had to specify I wanted mode 2.
My JR sets were available in 4 modes but McGregor Industries UK only imported mode 2. (easily altered by customer). My Graupner MC20 and Simprop 2000 can also be set to any mode.
Yes, the argument about which mode is best was going on 35 years ago.
But I cant see why you would want to buy a mode 1 (for arguments sake) and then convert it to mode 2?
Both my JR3810's came as mode 1 from my flying pal, Alan, in Cheshire. He wanted to sell them quick to finance buying the new digital trim version. He's mode 1 and I'm mode 2. Both sets were less than 3 months old.
The quick mode change solved both our problems. He got his new sets and I got a good deal. Some model shops do not have vast funds to stock everything. e.g. The set in stock won't sell because it's the wrong mode. This is cash tied up. If the set could be easily changed over, then it would go more easily.
Ahh Ok I see, but still its a bit 'picky' to slag off the dx7 because you cant swap modes!!!
» looking for yet another 35mhz futaba receiver...
» Looking for a receiver
» LIpo Batteries Servos and Receiver
