Full range Rx? Empty2019-07-12, 18:53 by Rich
Full range Rx? Empty2019-05-08, 17:49 by Gary M Jones
Full range Rx? Empty2019-04-14, 15:36 by Roy
Full range Rx? Empty2019-04-13, 16:49 by Roy
Full range Rx? Empty2019-03-03, 23:44 by Charles E Cornes
Full range Rx?
Full range Rx? Empty Full range Rx?
Post by Guest on 2010-02-26, 23:46
Hi
Is the ar500 a full range receiver?
And is it suitable for use in glow powered models?
If not, what is the cheapest full range dsm2 Rx available.
Full range Rx? Empty Re: Full range Rx?
Post by Mark Barnes on 2010-02-27, 09:59
yes it is Sam
Post by Guest on 2010-02-27, 10:00
Spektrum say it is. Check it out at their site http://www.spektrumrc.com/DSM/Products/airReceivers.aspx
Post by Guest on 2010-02-27, 10:33
It's a 5 channel full range receiver....
If you eventually want dual ailerons which have differential or flap function then you must do some tweaking :-
AR500 has two aileron ports, but it really is just an internal Y harness. To get dual aileron function with an AR500 you need to plug an aileron into the unused gear port and use one of the mixing functions on the radio.....
Plenty of advice on this on the net which you can get yourself
