» Sunday 20th May
Today at 12:54 pm by Allan Patrick
» Height restrictions on model aircraft
Today at 12:17 pm by Allan Patrick
» Hammer
Today at 11:55 am by Marty
» Seen this on "Fleabay" ??
Today at 11:45 am by Tim
» Models for Sale
Yesterday at 6:59 pm by Tim
Sunday 20th May
Sun May 20, 2012 11:11 am by Mark Barnes
Damm fine day for the field, who's going?
M - Who is awaiting Stubsy' s excuse
Comments: 8
Events 2012
Aerotow 2012
IMAC 2012
Click an event for more info
Pilatus Turbo Porter 96"
View previous topic View next topic Go down
Post by melfyn on Tue Dec 02, 2008 1:57 pm
Here are some photos of my latest project a Jamara 96" Pilatus Turbo Porter. I have yet to decide on an engine for it, at the moment it is a toss up between a 120 two stroke glow or a 26cc petrol.
The weight of the airframe at the moment with six servos, U/C and cowl but without engine, batteries, switches and throttle servo is 9 pounds.
The tail plane and undercarridge have been made removable to enable the fusellage to fit into the car. As well as the three M4 nylon hold down bolts the tailplane is also barced by a pair of 2mm steel rod struts.
Each of the strut braced two piece wings is located to the fusellage by a pair of 6SWG piano wire pegs and an M6 stud secured by an M6 nut and washer. The aluminium wing struts are of thick walled tube with a 90 degree bracket at the lower end which connects to an aluminium bracket on the fusellage, and a heavy duty M4 ball link at the top which connects to an M4 stud in the underside of the wing.
The undercarridge is not the original one, this being a heavy guage wire affair which was missing from the kit. The one fitted is a Carbon Copy quater scale unit.
I will add more pictures as the build progresses and provided Photobucket will allow me to upload more of them without having to pay.
RDMFC Bonus points: 528
Re: Pilatus Turbo Porter 96"
Post by Brian Colclough on Tue Dec 02, 2008 4:48 pm
Hi Mel that looks a deffinate candidate for having a glider release fitted to me, expect to be nagged by the aerowtow boys Wink
Club Site Webmaster
RDMFC Bonus points: 3593
Post by melfyn on Tue Dec 02, 2008 5:48 pm
Hi Bri, yes that idea had crossed my mind. I just need to work out the correct location on the fus for it. The other job I have in mind for it is a camera ship. So I shall include both items during the rest of the build.
Post by Brian Colclough on Tue Dec 02, 2008 6:13 pm
Mel if you want to go with a release have a chat with Rich Badham he'll put you right on that one Wink
Club Site Webmaster
Post by melfyn on Tue Dec 02, 2008 6:22 pm
Yes I'll do that, hopefully he will read this thread and reply with the info. If not I'll catch him ASAP and get his advice.
Post by Mark Barnes on Tue Dec 02, 2008 7:02 pm
Nice Bird Mel,
Defo needs to be a tugger mind, and good luck with the camera ship idea, I used my blue and pink one with my HD video camera last year but the result was poor with all the vibration
Look forward to seeing it come togeter
RDMFC Bonus points: 4628
Pilatus Porter update
Post by melfyn on Fri Dec 12, 2008 5:33 pm
Well It's almoast complete, just a few odds and ends to finish off. The engine I finally chose is a CRRC Pro GF26i petrol, a very compact little unit and fairly light too. As can be seen from the photos the cowl which started as a ten inch long substantial ABS moulding has been reduced to just a tad over four inches in length.
Here are some up to date photos:
Post by Brian Colclough on Fri Dec 12, 2008 5:39 pm
That's looking good Mel, I have a feeling John Barrows has got the sister ship to that in the Blue and white scheme, look forward to seeing it fly Wink
Club Site Webmaster
Post by Rich on Sun Dec 14, 2008 2:45 pm
Hi Mel,
Looks like a nice installation your going on with, here's a link to a couple of different release methods pick the one that suits your airframe, the release needs to go in the fuz not the wing. I've used them all in the past, keep it simple is the best advice I can give. Give me a call if you need persuading at all
http://www.scalesoaring.co.uk/VINTAGE/HintsTips/Articles/TowReleases/FittingRelease.htm
RDMFC Bonus points: 2893
Post by melfyn on Fri Jan 09, 2009 5:45 pm
Here are the specs for the completed model:
Wingspan 96" 2,438.4mm
Overall length 69.5" 1,765.3mm
Wing area 1,344 sq in 8.656 sq mtrs
Weight 13.25lb 6 Kg
Engine CRRC Pro 26cc petrol, prop JXF 18" X 6"
Rx Futaba R149DP 9chan PCM
Servos Supertec Mini standard X 4, Tower Pro MG995 X 2, Tower Pro SG5010 X 1
RX battery GP 2100 Mah 6V 4/5AF NiMH Ignition battery 1100 Mah 4.8V AA NiMH
Post by Andy Sayle on Mon Jan 19, 2009 9:55 am
Looks good that Mel, I bet it would go nice with a Wren Turboprop in the nose Smile Smile
Mark's sacked builder - But nevertheless, he did a bloody good job at building his Binary..
RDMFC Bonus points: -487571904
Post by melfyn on Tue Jan 20, 2009 1:48 pm
Yep probably would, but way beyond my budget I'm affraid silent
Post by Andy Sayle on Tue Jan 20, 2009 2:09 pm
We'll just have to make the wooshing noises in our heads then Smile Smile
View previous topic View next topic Back to top
