Ok lads heres my proposed design.
wing is 3/16th sheet and fins are 8th with a couple of other bits. The canopy is just a rough guess but i think it finishes it off nicely. i could vac form some if we decide to use um.
Ok proposed rules.
2 classes, standard and unlimited.
Standard:-
model to be built as per plan no lightening holes or carbon etc.
Covering is builders choice
motor must be an unmodified cox .049 sure start with starter spring and plastic backplate.
All racers will run the same fuel. (fuel to be dispensed before race)
Unlimited:-
Model may be modified but must retain the size and outline of the original plan.
Any .049 glow motor may be used modified or otherwise
Any fuel may be used
Motor position is optional i.e pusher.
Thats the basic idea. so whats everyone think??
» Selling up
» Airframes for sale
» Orming Tuesdi
» Black Mike (PSS)
