    BMFA Achievement scheme  Empty2019-05-08, 17:49 by Gary M Jones
    BMFA Achievement scheme  Empty2019-04-14, 15:36 by Roy
    BMFA Achievement scheme  Empty2019-04-13, 16:49 by Roy
    BMFA Achievement scheme  Empty2019-03-03, 23:44 by Charles E Cornes
    BMFA Achievement scheme  Empty2019-02-10, 16:31 by melfyn
    BMFA Achievement scheme  Empty BMFA Achievement scheme
    Post by Mark Barnes on 2018-08-28, 20:18
    After a few discussions and questions i thought id post a BMFA Achievement scheme guide for you all to look at
    Although I'm always happy to answer your questions most of what you need can be found on the BMFA Achievement website http://achievements.bmfa.org
    The Program
    All "tests" in the scheme follow the same basic layout so no matter if you trying your first crack at a basic proficiency cert, an A or your a hardened flier going for a B or C, all tests follow the same basic program
    -Practise and Revision, I can tell you what to do but i can't do it for you.
    -Pre flight checks
    -Flying the test
    -Post Flight checks
    -Mandatory questions
    -Another set of safety questions
    -Pass Certs and cheers from your fellow fliers
    Have a look through he website above and you will see whats required, the key is to be safe and not rushed. It may seem daunting at first but there really not to bad if you put a little effort in before hand. The questions may seem tough and pointless but each one if there because of the Law or to keep you and your fellow man safe.
    If you want to know anything in particular or need a helping hand just shout on here, or Whattsapp or catch me down the filed.
    Ta M
    BMFA Achievement scheme  Empty Re: BMFA Achievement scheme
    Post by Mark Barnes on 2018-08-28, 20:30
    The BMFA Achievement Scheme Fixed Wing A Cert (as I've been asked)
    The flying part of the test is as follows
    1. Pre flight Checks
    2.Take off and complete a left (or right) hand circuit and overfly the    take-off area.
    3.Fly a "figure of eight" course with the cross-over in front of the pilot, height to be constant.
    4.Fly a rectangular circuit and approach with appropriate use of the throttle and perform a landing on the designated landing area.
    5.Take off and complete a left (or right) hand circuit and overfly the take-off area
    6.Fly a rectangular circuit at a constant height in the opposite direction to the landing circuit in (4) above
    7.Perform a simulated deadstick landing with the engine at idle, beginning at a safe height (approx. 200 feet) over the take-off area, the landing to be made in a safe manner on the designated landing area.
    8.Remove model and equipment from the take-off/landing area
    9. Carry out post flight safety checks
    You will not have to remember the moves as each one will be called by the examiner, it does not need to be flow as a aerobatic routine each figure can be flown individually but i the same flight.
    The designated landing zone is the strip.
    Im more than happy to run through this or any test with members as and when they wish (if I'm at the filed of course) Im not going come and ask you to do it if you want me to just ask
    Ta M
