Mini Wot 4 ARTF
Mini Wot 4 ARTF
Its been an age since there was a build thread on here so i thought I would do one over xmas for you all,however it hasn't gone quite to plan.....
A trip to Steve Webb Models on Thursday night saw me pick up one of the new Mini WOT 4 ARTF from Chris Foss and Ripmax, everything in the box except RX and lipo
Specifications
Propeller 5.5 x 4.5" (Inc.)
Wingspan 670mm (26.4“)
Length 570mm (22.4")
Weight 260-280g (9.2-9.9 oz.)
Servos 4 x Micro (Inc.)
Radio System 4-5 Channel (Req.)
LiPo 2S1P 7.4V 650-800mAh (Req.)
Electric Motor 1510 Brushless (Inc.)
Speed Controller 10A Brushless (Inc.)
So onwards to open the box
All very nice, first job cyno all the mylar hinges in the pre cut slots
Dont do the bottom one yet as this glues into the base of the fuz
Specifications
Re: Mini Wot 4 ARTF
with that done you next set is to add a couple of small extension leads into the wings for the Ali servos, theres some string pre installed to help this process
next servos are put in and control rods attached (after gluing the horn into the control surface)
tadaaaa wing all done, less than 20mins after opening the box
Re: Mini Wot 4 ARTF
Very nice indeed.
good post.
good post.
Andyedmead- Posts : 67
RDMFC Bonus points : 107
Re: Mini Wot 4 ARTF
looks nice , has it flown yet ?
Gary M Jones- Posts : 203
RDMFC Bonus points : 341
Re: Mini Wot 4 ARTF
Not yet Gary, I will update once it has. Hopefully this weekend if the weather breaks
Re: Mini Wot 4 ARTF
|Is the wing built up too?
Re: Mini Wot 4 ARTF
Yes built up wing
Re: Mini Wot 4 ARTF
At long last the mini wot4 has flown.......
Overall it went well. I've got a slight false neutral in the elevater, due I think to a tight hinge, and it's abit nose heavy at present but both are easy fixed when I get a sec.
You can't slow it down to much, as I expected she will bite, but in truth if you forget the modern artf Wots the originals were all like that. So speed must be kept on.
Flat out she's traveling a bit but not to fast, I've seen reports wanting more power but I feel it's a calm day plane and it had ample for everything i could throw at it. Its not a plane for big long verticals!
Rolls were crisp and it loops and stall turns fine. Knife edge was tricky but once the balance is sorted I will revisit that.
The undercart is weak and bent on every landing but the plane is so light your gonna struggle to do any big damage on landing.
All in all quite good.
