» Aldi
» Wild Hare Edge 540
2019-01-11, 19:21 by Mike S
» Happy Christmas
» Spirit 600mm Racing Wing FPV KIT
2018-10-19, 20:38 by Andyedmead
» Items for sale!
2018-10-09, 15:59 by Andyedmead
DX8 queery
DX8 queery
Post by Gary M Jones on 2017-12-29, 20:32
Has anyone tried to set up a DX8 with the following .... 2 x aileron , 2 x elevator, throttle, rudder, single flap, retractable u/c. Mostly works except for u/c. This operated in conjunction with the flaps & semi operated with movement of the rudder !! Can't get it to play after spending too much time trying. 2 different Rx's tried with the same result. I think it does not like flap & retracts. No mixes were set up.
Found a way round it however with the following .... 'Y' lead ailerons , 2 x elevator , throttle, rudder, single Flap, retractable u/c . This all works ok . I did find that Tx mode 1 uses the opposite side equivalent position switch on the Tx for u/c ! & it is in the manual.
It could be that Aux 1 ( aileron) & Aux 3 (for flap) don't agree with u/c which maybe should be Aux 2 ? even when in the Gear slot.
Earlier generation computer radios were a lot simpler
I was almost verging on going back to 35Mhz with a Field Force 7 Smile
Gary M Jones
Gary M Jones
RDMFC Bonus points : 330
Re: DX8 queery
Post by Rich on 2017-12-30, 06:07
Sorry Gary you lost me when you mentioned DX8
RDMFC Bonus points : 5622
Re: DX8 queery
Post by Mark Barnes on 2017-12-31, 10:46
Normally with tricky set ups like this is you will find a mix is turned on somewhere, spectrum and jr were always a bit odd once you started playing with flaps. The transmitter makes assumptions on your behalf that normal messes stuff up.
Re: DX8 queery
Post by Gary M Jones on 2018-01-09, 20:41
Thanks , thought that may be the case with so many channels. Sorted now using the old "Y" lead for ailerons. Unusually the u/c switch does not function as such in Mode 1 so that too may play a part in the electronic "workings" . The switch on the r/h side of the Tx does the biz as per handbook very small print.
Gary M Jones
Gary M Jones
Re: DX8 queery
