Mini Wot 4 ARTF Empty2019-07-12, 18:53 by Rich
Mini Wot 4 ARTF Empty2019-04-14, 15:36 by Roy
Mini Wot 4 ARTF Empty2019-04-13, 16:49 by Roy
Mini Wot 4 ARTF Empty2019-03-03, 23:44 by Charles E Cornes
Mini Wot 4 ARTF Empty2019-02-10, 16:31 by melfyn
Mini Wot 4 ARTF
Mini Wot 4 ARTF Empty Mini Wot 4 ARTF
Post by Mark Barnes 2017-12-23, 16:21
Its been an age since there was a build thread on here so i thought I would do one over xmas for you all,however it hasn't gone quite to plan.....
A trip to Steve Webb Models on Thursday night saw me pick up one of the new Mini WOT 4 ARTF from Chris Foss and Ripmax, everything in the box except RX and lipo
Specifications
Propeller 5.5 x 4.5" (Inc.)
Wingspan 670mm (26.4“)
Length 570mm (22.4")
Weight 260-280g (9.2-9.9 oz.)
Servos 4 x Micro (Inc.)
Radio System 4-5 Channel (Req.)
LiPo 2S1P 7.4V 650-800mAh (Req.)
Electric Motor 1510 Brushless (Inc.)
Speed Controller 10A Brushless (Inc.)
So onwards to open the box
Mini Wot 4 ARTF Thumb_10
All very nice, first job cyno all the mylar hinges in the pre cut slots
Mini Wot 4 ARTF Thumb_11
Mini Wot 4 ARTF Thumb_12
Dont do the bottom one yet as this glues into the base of the fuz
Mini Wot 4 ARTF Thumb_13
Mini Wot 4 ARTF Empty Re: Mini Wot 4 ARTF
Post by Mark Barnes 2017-12-23, 16:24
with that done you next set is to add a couple of small extension leads into the wings for the Ali servos, theres some string pre installed to help this process
Mini Wot 4 ARTF Thumb_14
next servos are put in and control rods attached (after gluing the horn into the control surface)
Mini Wot 4 ARTF Thumb_15
tadaaaa wing all done, less than 20mins after opening the box
Mini Wot 4 ARTF Thumb_16
Post by Mark Barnes 2017-12-23, 16:28
onto the fuz now, all nicely made ply and balsa construction
Mini Wot 4 ARTF Thumb_17
nice strong looking motor box
Mini Wot 4 ARTF Thumb_18
undercart assembled and installed in less time that in took the wife to brew up.
Mini Wot 4 ARTF Thumb_19
Mini Wot 4 ARTF Thumb_20
Mini Wot 4 ARTF Thumb_21
Post by Mark Barnes 2017-12-23, 16:31
onto the tail, all control horns added, the stab slot is pre cut so just a bit of measuring and covering removal for the glueing surfaces to do, then cyno the lot to the fun
*note the tail skid added to (seem to have lost that pic)
Mini Wot 4 ARTF Thumb_22
Mini Wot 4 ARTF Thumb_23
Mini Wot 4 ARTF Thumb_24
Post by Mark Barnes 2017-12-23, 16:37
next up ass the 2 tail servos to the radio bay and install the control rods, i diverted from the instructions here as they say put the z bend on the tail and the adjusters in the fus I did it the other way round.
Mini Wot 4 ARTF Thumb_25
Mini Wot 4 ARTF Thumb_26
Mini Wot 4 ARTF Thumb_27
Mini Wot 4 ARTF Thumb_28
Post by Mark Barnes 2017-12-23, 16:40
Motor and 10mp ESC installed next, I forgot to take pics of the esc but you have to add your own power plug to it i.e deans, xt40, gold bullets etc etc
Mini Wot 4 ARTF Thumb_29
Mini Wot 4 ARTF Thumb_30
Mini Wot 4 ARTF Thumb_31
Post by Mark Barnes 2017-12-23, 16:42
With the motor and esc installed its onto final finishing, i cut the cooling slots and installed the closer on the battery hatch
Mini Wot 4 ARTF Thumb_32
Mini Wot 4 ARTF Thumb_33
Mini Wot 4 ARTF Thumb_34
Post by Mark Barnes 2017-12-23, 16:46
Plastic cowl next, the instructions say use 3 supplied screws, i wanted to keep it looking clean so used 2 pieces of double sided sticky foam to secure, seems to work well
Mini Wot 4 ARTF Thumb_35
RX added, plenty of room for a normal 6chan in the bay, and all thats left is to program
Mini Wot 4 ARTF Thumb_36
Post by Mark Barnes 2017-12-23, 16:47
so there you have it, a xmas build done in less that 3 hours. I'm gonna have to go and talk to the family now ................
Mini Wot 4 ARTF Thumb_37
Mini Wot 4 ARTF Thumb_38
Mini Wot 4 ARTF Thumb_39
Post by Andyedmead 2017-12-24, 22:17
Very nice indeed.
good post.
Andyedmead
RDMFC Bonus points : 107
Post by Gary M Jones 2017-12-29, 20:13
looks nice , has it flown yet ?
Gary M Jones
Gary M Jones
RDMFC Bonus points : 341
Post by Mark Barnes 2018-01-02, 20:59
Not yet Gary, I will update once it has. Hopefully this weekend if the weather breaks
Post by Andy Sayle 2018-01-06, 21:53
|Is the wing built up too?
Post by Mark Barnes 2018-01-06, 22:40
Yes built up wing
Post by Mark Barnes 2018-01-20, 17:50
At long last the mini wot4 has flown.......
Overall it went well. I've got a slight false neutral in the elevater, due I think to a tight hinge, and it's abit nose heavy at present but both are easy fixed when I get a sec.
You can't slow it down to much, as I expected she will bite, but in truth if you forget the modern artf Wots the originals were all like that. So speed must be kept on.
Flat out she's traveling a bit but not to fast, I've seen reports wanting more power but I feel it's a calm day plane and it had ample for everything i could throw at it. Its not a plane for big long verticals!
Rolls were crisp and it loops and stall turns fine. Knife edge was tricky but once the balance is sorted I will revisit that.
The undercart is weak and bent on every landing but the plane is so light your gonna struggle to do any big damage on landing.
All in all quite good.
Mini Wot 4 ARTF 20180150
