Skywalker X-6 FPV Wing EPO 1500mm (Kit)
RDMFC :: Classifieds
Skywalker X-6 FPV Wing EPO 1500mm (Kit) new in box
The X-6 FPV wing from Skywalker Technology has been specifically designed for FPV and UAV applications. It was optimized for a large wing area and light weight allowing a much greater payload. An awesome looking and fantastic flying FPV / UAV platform, molded out of EPO so it's nearly indestructible!
The airframe was designed from the outset to take FPV and other video devices. Separate cavities in the model allow you to mount your FPV transmitter or other equipment futher away from the flight receiver, reducing the chance of interference. Serial style connectors at each wing root means assembly and disassembly is very easy, no need to fiddle with servo connectors.
Arriviing as a kit, the X-6 is a blank canvas for you to fully customize your FPV and flight control setups. A voluminous battery bay accepts a wide variety of packs or extra flight equipment.
It's an impressive airframe that spans 1500mm and has a rather imposing silhouette!
Features:
• Kit - Assemble and install your choice of electronics
• Molded EPO Airframe
• Detachable wings with quick secure servo connections
• Separate cavities for installing your FPV transmitter
• Carbon spar increases rigitidy
• Accepts a wide variety of battery sizes
Specs:
Wingspan: 1500mm
Length: 660mm
Airframe Weight: 770g
Required:
6 CH transmitter and receiver
3~4S 11.1~14.8V 2200~4000mAh lipoly battery
2814 kv980 or 3815 kv1000 Brushless Motor
£60
Features:
Specs:
Wingspan: 1500mm
Length: 660mm
Required:
£60
Re: Skywalker X-6 FPV Wing EPO 1500mm (Kit)
I will have it gary
