    2019-02-10, 16:31 by melfyn
    » Aldi
    » Wild Hare Edge 540
    2019-01-11, 19:21 by Mike S
    » Happy Christmas
    flaperons
    flaperons
    Post by andy-kaz on 2015-10-17, 19:08
    i'm a bit stuck boyz. im trying to set flaperons on my libelle and i'm struggling. ive set the switch ie f-mode but when I flick it the ailerons end up one up one down. anybody shed any light on how to sort this out on a speki 8.
    andy-kaz
    andy-kaz
    RDMFC Bonus points : 1337
    Re: flaperons
    Post by Rich on 2015-10-18, 09:42
    do you have two servos in the wing one for each aileron
    RDMFC Bonus points : 5630
    Re: flaperons
    Post by Tim on 2015-10-18, 13:21
    If you don't then it can't be done.
    If you DO, then ensure that you have set wing mix correctly in sub menu, and also that flaps are actually enabled in the same menu. Once you have established those, then a fiddle about with servo revers and trim should have it working. Have you checked whether there are any preset mixes to download ( SPM files ) from spektrum website for the libelle or similar? That's the easiest way to set up models on the DX8.
    Re: flaperons
    Post by andy-kaz on 2015-10-18, 18:29
    yep, there are 2 servo's in the wing. ive been fiddling with the settings and mixers but still cant quite get it working properly. will keep messing with it. thanks lads
    andy-kaz
    andy-kaz
    Re: flaperons
    Post by Guest on 2015-10-19, 09:44
    have you tried swapping the servo leads over on the rx Andy
    Re: flaperons
