Yesterday at 10:53 am by Andyedmead
BHM and empty field
BHM and empty field
Post by Tim on Mon May 26, 2014 7:46 pm
Arrived to sunshine and light breeze around 2.30PM and no-one there!
Jem arrived shortly afterwards, and then Mel and Steve Price.
First off I flew my Radjet 800 ( now fitted with a new receiver which seems to have fixed the erratic flight behaviour of last seasons later flights )
Next up was the refurbished Electraglide which is now back to its normal well behaved self, and then we did some fun aerotowing with Steves Cub Tug, and my trusty 12oz Weasel. Then I had a couple of flights with the Bede.
I tried a new phone app out "Hobby King Doppler" for speed measurement of the models, and although it seemed a bit fussy about flight direction, when it did record properly they were mostly quite consistent, and I got the following avg readings
Radjet 108 MPH
Bede 75-80 MPH
Jems 450 Heli, a surprisingly fast 55MPH
Its got a few issues that I will research, but all in all, pretty good fun for a couple of dollars  Very Happy
RDMFC Bonus points : 3227
Re: BHM and empty field
Post by Mark Barnes on Mon May 26, 2014 10:17 pm
maybe a post before you went to the field would have brough more members out.
I had a good day to
RDMFC Bonus points : 8185
Post by Tim on Mon May 26, 2014 10:59 pm
Nice Pics Mark - Rhuddlan castle?
Post by Mark Barnes on Tue May 27, 2014 8:37 am
only in the background
Post by Brian Colclough on Tue May 27, 2014 9:03 am
St Mary's church in the foreground Wink
Post by Rich on Tue May 27, 2014 12:36 pm
Nice Sun on the way to set must have been late
RDMFC Bonus points : 5558
Post by Mark Barnes on Tue May 27, 2014 1:46 pm
Rich wrote:Nice Sun on the way to set must have been late
about 21.30 Rich from East end of the prom infront of The Marina Apartments, sat on the bench flying out over the sea wall. Mel on people watch, while eating a chippy tea.
Them carbon props are smooth as silk BTW, not tried the other special yet but have it all mounted on the FPV quad, fits well to be fair will give it a wrirl tonight.
Post by Rich on Tue May 27, 2014 2:42 pm
Looks like you bought it then by the look of it
Post by Mark Barnes on Tue May 27, 2014 3:13 pm
has your gaypro arrived then has it lol
Post by Allan Patrick on Tue May 27, 2014 3:17 pm
Played about with speed measurement a few years ago using, I think, a German software product. It was not very easy to use but gave good results when you got it right. One had to record the sound with something - we found a pocket dictaphone worked quite well, then play the recording into a PC to digitise it and open it in Audacity using the FFT display (Fast Fourier Transform). Then using the cursor measure the approach and depart frequencies, input this manually into the prog and out would pop the answer. I'll look up the product when I get home
To get good results you had to fly directly at the microphone, and past. This is because the doppler shift is for the sound coming from a source moving directly towards or away from you. Think of the doppler you hear from a vehicle if you are stood in a layby on a busy road - a large doppler - compared with the small doppler you get at the field pits from the cars on the road. Similar speeds but not directly towards/away to you. We found this decidedly hairy so put the dictaphone on a pole a safe distance away!
There were two other major sources of error. The first was that the prop was not a reliable sound source as the revs change - hence audio frequency - as the speed changes. A slight dive into the approach or straightening out after turning in caused significant errors.
To reduce errors due to revs changing I made a simple electronic circuit to drive an ordinary piezo sounder with 100Vac at 4 kHz to make it nice and loud. This sound was easily seen on the PC FFT display
The second error was not flying in a straight line... One would easily, in reality, fly a big curve. The best solution we found was to set up the approach then to release the sticks and let the plane fly itself - fast and low - all good fun. If you touch the sticks the plane turns, drag changes , the speed changes and the errors appear. Especially if you are using the sound from the prop. The FFT display showed up these errors very clearly!
It definitely all works but the physics means a lot of attention to detail. Perhaps a radar gun? Nevertheless all good fun for a couple of quid!
RDMFC Bonus points : 1805
Post by Rich on Tue May 27, 2014 9:34 pm
Mark Barnes wrote:has your gaypro arrived then has it lol
NO
Not fussed about the trick piece of kit you have but I want my micro SD card back tomorrow.
Post by Mark Barnes on Tue May 27, 2014 9:54 pm
no probs,drop it off in the morning on the way through if your up, im rugby tomorrow night then london rest of the week
