JR Forza 450 build thread. Empty2019-07-12, 18:53 by Rich
JR Forza 450 build thread. Empty2019-05-08, 17:49 by Gary M Jones
JR Forza 450 build thread. Empty2019-04-14, 15:36 by Roy
JR Forza 450 build thread. Empty2019-04-13, 16:49 by Roy
JR Forza 450 build thread. Empty2019-03-03, 23:44 by Charles E Cornes
JR Forza 450 build thread. Empty JR Forza 450 build thread.
Post by Mr Moff on 2013-07-04, 22:41
Evening peeps,
I thought I'd get this new build underway, it's my first JR build so I'm looking forward to this one.
My favourite 450 has been the Rave for a while now so I'm going to find where this fits in.
Anyway, this is the combo version that comes with all servos,esc motor and blades.
The tail has the 3500G which is my favourite mini tail servo.
The cyclic servos are ds21's which are new out so hopefully they should be pretty good.
JR Forza 450 build thread. 232f17e8c8d345c424118232021fd237
Presentation when you open the box is 10 out of 10, very impressive.
JR Forza 450 build thread. 385047b988ce40df2972b0888294db8e
JR Forza 450 build thread. 72afaeb38716459c5a681a632b48414b
JR Forza 450 build thread. 6d02190a4f7735f7640b89413ebc18fe
The ESC deserves a special mention with some great specs,
3 to 6s lipo
50A continuous
Switching bec rated at 5A
Adjustable voltage in 4 steps from 5v to 6v
Something I like is the fact that all the esc wires are coming out of one side. This means the other end of the esc has some rubber padding heat shrunk on it.
This means when mounting this under the battery tray you can slide it all the way up without fear of the motor wires chaffing on the pinion. Great stuff.
JR Forza 450 build thread. B229731f3b00bb9aac613d081e8ad296
So that's just a quick look at opening the box and build will commence shortly.
Planning on running this one on 6s but for the build I'm just gonna use 3 or 4 s.
Anyway I'm off to do a little building so see you a bit later.
JR Forza 450 build thread. Empty Re: JR Forza 450 build thread.
Post by Mr Moff on 2013-07-07, 02:21
A little late night update,
The servos use a neat idea to avoid using subtrim. Some little metal sleeves go over the splines and the screw holds them in place.
Then you put on the servo arms and centre your servos, following which you move them at 90 degrees and tighten a little 1.5 bolt that clamps the servo down.
A neat little idea.
JR Forza 450 build thread. Df148170165b1652c3a4fd1fabc2da9f
JR Forza 450 build thread. C36fb3b6c92f12f60c4bfcd5b5f00852
JR Forza 450 build thread. 0acac3a0e7032b416d536720c127d3b9
Post by Mr Moff on 2013-07-07, 02:23
Servos attached to the main shaft bearing blocks and the main shaft holds them in line while you screw them down.
The main shaft is thicker than the other 450's at 6mm thick.
JR Forza 450 build thread. 98e42555b50811c3f09dc84724ada6a6
Post by Mr Moff on 2013-07-07, 02:29
The carbon frames are some of the nicest cut carbon I've ever seen. All screw holes are drilled perfectly and even the edges are perfectly smooth.
You still need to sand the edges though but the finish is top draw.
JR Forza 450 build thread. 72893013e80892ea4748e3a4b10789eb
Both frames are universal in that they aren't handed so you can't get it wrong.
I built one side up and left out any thread lock until both frames were together.
Also the main shaft has no top or bottom so it can be installed either way up.
JR Forza 450 build thread. 8afb8d370547374569a6dff7b2c8974d
Post by Mr Moff on 2013-07-07, 02:33
JR Forza 450 build thread. Cf66826edec2499a8872465861c1ef57
JR Forza 450 build thread. D58195776dd5de10f2f8957a77762e26
Both frame sides together and starting to take shape.
JR Forza 450 build thread. D0ab873780d9f470cc4a11bf83ec4f01
JR Forza 450 build thread. Bb94a0183e9d25fb9d9636f31b175691
Post by Mr Moff on 2013-07-07, 12:08
Something that is done differently is with the main gear and pinion.
The main gear doesn't have a one way bearing, it's just the gear. They've put the one way in the pinion instead.
This keeps the cost of the main gear down but makes the pinion choice limited to just the JR pinion. It also makes things tricky if you want to use a different motor because the motor shaft is unique and designed to go with the pinion.
The msh mini protos is the only other heli that uses the same type of arrangement.
JR Forza 450 build thread. Bf1d797c0d6c330f3cdfaaea47d5bafd
JR Forza 450 build thread. B990f8f5fad9c1de86d665aa8b1e305b
JR Forza 450 build thread. 3c7e3c7ea043804ce2d78c384f3a958a
JR Forza 450 build thread. 703f1ef121a8c85f3182377b5cd0ac5e
Post by Mike S on 2013-07-07, 19:11
Very nice that Danny. Do you have trouble sleeping at night???What a Face
RDMFC Bonus points : 466
Post by Mr Moff on 2013-07-07, 23:24
Thanks mike, yeah my back tends to keep me awake at night a lot, so if something's on the table I do a few bits.Very Happy
Post by Mr Moff on 2013-07-08, 00:43
Swash and linkages, swash is also serviceable if you need to change the bearing.
JR Forza 450 build thread. E15104baffdb44032895e14c6ddc947d
Head assembled.
Something to note is all the prebuilt parts like the head,swash and tail all had thread lock and the thrust bearings had grease in them.
The main blade grips have the usual 2 radial bearings per grip. Usually after the outer bearing is in place, you then install the thrust bearings with the washer and spindle bolt.
On this they've put the thrust bearings in between the 2 bearings in the blade grips. As such they are nicely sealed from the elements and the grease won't escape.
The pitch links are also incredibly thick.
With the main shaft being 6mm thick you will have trouble finding a swash levelling tool that fits, but not to worry because they include a small plastic one that clips under the swash.
JR Forza 450 build thread. 66a438fb97a071595be2b71e4eb9322c
Post by Mr Moff on 2013-07-08, 01:00
Just a quick note about the esc and your flybarless controller.
A lot of esc's require full throttle on power up to enter setup mode. Some fbl units won't let the esc arm until it senses that the throttle is off.
What I do to remedy this is to use an old reciever, and just hook up the esc and motor.
This lets you setup your esc and then you just bind to your flybarless unit and the programming is already done then.
Post by Andy Sayle on 2013-07-08, 11:30
What FBL controller are you using Danny? I've got a 7200bx here, with a dsmx satellite I was going to sell if you want it. I'm not going to be using it on my 550....
It looks liek a really well thought out kit this one though.
Post by Mr Moff on 2013-07-08, 22:48
That's the one I'm using in this Andy.
How much do you want for them?
Post by Mr Moff on 2013-07-08, 22:53
Tail assembled and ready for the boom.
JR Forza 450 build thread. 51a3096b29a4a16151a7e39277f89ddf
And now for the finished pics,
JR Forza 450 build thread. Ef075bab997f4b74c924902a38a814ef
JR Forza 450 build thread. 2e2f7f5bd08f5160f036382835080876
Easy to do neat wiring on this one.
JR Forza 450 build thread. Fb85d442ac059131b1fda65d5942ac94
Post by Mr Moff on 2013-07-08, 22:59
Final pics before maiden, note the canopy wraps around the head, then covers the fbl unit.
JR Forza 450 build thread. 0ffa8b7c6ca7efcb6b7655a647edce48
Very long boom which is why it will swing 350mm blades.
JR Forza 450 build thread. B77429b5cef57a95ffa4e8f218dca0ed
Also the heli tilts forward. If you look at the boom in the picture below you'll see it is angled upward. This also gives the tail decent ground clearance in tall grass
JR Forza 450 build thread. C1a855ed620acba640d8d97ed240078f
Post by Mark Barnes on 2013-07-09, 08:24
The maidens seemed to go well last night Danny, loverly looking Heli as well.
Post by Andy Sayle on 2013-07-09, 09:53
Mr Moff wrote:That's the one I'm using in this Andy.
Dunno, make me an offer if you want them, I've got the controller, dsmx satellite, and the USB programming dongle thingy. I'm not going to be using it, instead I'm saving up for something a bit more advanced Wink
Post by Mr Moff on 2013-07-09, 11:23
Hmm, how does £80 sound?
Post by Mr Moff on 2013-07-09, 21:30
Sold,thanks Andy.
Post by Brian Colclough on 2013-07-10, 08:59
A couple of flying shots of Danny's Forza from last night at the field a beautifully engineered little machine as JR stuff usually is, having just researched the price so it should be Wink
JR Forza 450 build thread. Img_3911
JR Forza 450 build thread. Img_4010
Post by Mr Moff on 2013-07-10, 10:32
Thanks Brian, cracking photos as always.
Post by Mr Moff on 2013-07-10, 11:39
Conclusion time,
I've had around 20 flights on the Forza now and the way it flies is simply sublime.
Right from the off it feels so comfortable and you instantly know you're flying something a bit special.
The motor/ESC combo match the model well, being very quiet with plenty of power.
Flying this on 3s is very similar to flying the Rave on 4s,which is a huge compliment.
All the pre assembled parts were built correct at the factory, and the pitch links were even the correct length for zero degrees at mid stick.
There is no slop or binding anywhere.
The canopy looks great in the air and is easily visible from a distance. The only thing about the canopy I don't like is the fact that its so tight over the battery. I'm using thunder power 2250's 3s 70c and it only just fits under there. There's no way anything bigger will fit under it, so 4s packs are a no go at the moment.
PRO's
Build quality
High quality servos
Plenty of power
Canopy visibility
Able to swing 350mm blades out of the box
6mm main shaft
Very easy to build, could probably build in around 4 hours
CONS
Canopy a tight fit
Thirsty motor/esc, I am getting 5 mins and using nearly 80%. I wouldn't use batteries under 40C because I think it would be quite hard on them
Cost of parts
This is definitely my favourite 450. In fact I'm enjoying it so much this leads me straight onto my next build.Laughing
