» LLanfair TH Village Fete Saturday 28th July 1030
Yesterday at 8:11 am by Mark Barnes
» SC engines?
Sun Jul 15, 2018 6:07 pm by Gary M Jones
» Saturday 14th/Sunday all nighter
Sat Jul 14, 2018 9:18 pm by Gary M Jones
» sunday 8th
Sun Jul 08, 2018 10:48 pm by andy-kaz
» Saturday 7/7/18
Sun Jul 08, 2018 8:38 am by andy-kaz
Maintenance
Maintenance
Post by Brian Colclough on Mon Jan 28, 2013 5:41 pm
Started working my way through my gear in the hope of better weather being round the corner, had a couple of R/X nihm packs in my gliders that took 4 or 5 cycles to get back up to speed, at first I thought they were goners. I've also ordered new servos for the Sbach as they've been jittering for a couple of seasons now and I'd already subtrimmed them a couple of times to offset the pots which did mute the jittering for a while but it's time to bite the bullet and splash the cash. I've gone for 4 of a fairly new Hitec offering HS-5585MH They're a budget priced digi which are high voltage tolerant and metal geared. The specs plenty good enough for a 50 cc model. They're fairly new to the market so haven't found any reviews at all so chancing my arm a little but I've had good service with Hitecs in the past. Watch this space I suppose What a Face
Re: Maintenance
Post by Mark Barnes on Mon Jan 28, 2013 6:20 pm
Hope there better than the hs-35 and 5035 models. Be interesting to see how they go
RDMFC Bonus points : 8225
Re: Maintenance
Post by Brian Colclough on Mon Jan 28, 2013 6:34 pm
I'll second that Mark HS 35 went tits up on my Ramiel elevator on Saturday.
Re: Maintenance
Post by Guest on Mon Jan 28, 2013 8:53 pm
AND I had the same problem with the hs 35s on the ramiels.
Re: Maintenance
Post by Mr Moff on Mon Jan 28, 2013 11:12 pm
+3 on the hitec 35's. I had 6 of them but only 2 worked out of the box.
Re: Maintenance
Post by Guest on Tue Jan 29, 2013 9:52 am
tower pro 5 gram just cant beat them for the price never had one fail Very Happy
Re: Maintenance
Post by Andy Sayle on Tue Jan 29, 2013 10:49 am
IS that because you hardly ever use them?
RDMFC Bonus points : -487569795
Re: Maintenance
Post by Tim on Tue Jan 29, 2013 1:15 pm
I love my HS35s - bought 6 and all appear fine. Very Happy
Thats done it !
RDMFC Bonus points : 3233
Re: Maintenance
Post by Brian Colclough on Tue Jan 29, 2013 2:03 pm
Great when they're working pirat
Re: Maintenance
Post by Robert Piechulski on Tue Jan 29, 2013 4:22 pm
My 2 pence if you don't mind ?
There is a very high percentage of them not working out of the box :/
Hitec exchanges them with no problems - but still - at this price all should be checked for any faults before sending from the factory.
I got annoyed at one point and now before sending to customer I just run it for a moment on the servo tester - had no reports of them stopping work tho, our test model aerodepron Ram - was flown hard by Connor and he didn't manage to kill them.
All in all it's a bad thing - only competition in this class is dymond, sd and lsx - apart from that those are the same servos - the lsx looks like are no longer distributed in the UK.
JR are also very good - but 1.5g heavier so if the weight is on the scale then might be an issue .
Sorry for cutting in Wink
Robert Piechulski
RDMFC Bonus points : 583
Re: Maintenance
Post by Brian Colclough on Tue Jan 29, 2013 4:26 pm
Mine just went into vibration mode may covert to use as a sex toy Suspect
Re: Maintenance
Post by Robert Piechulski on Tue Jan 29, 2013 4:30 pm
In that case I'd say you got yourself a bargain Very Happy
Robert Piechulski
Re: Maintenance
Post by Tim on Tue Jan 29, 2013 5:04 pm
Would that be a covert sex toy then Brian? - I guess its probably best :-)
Re: Maintenance
Post by Brian Colclough on Tue Jan 29, 2013 5:07 pm
Definitely gotta put it somewhere it can't be seen Wink
Re: Maintenance
Post by Mark Barnes on Tue Jan 29, 2013 7:28 pm
As you say rob, not a lot of choice in this size its a pain. As Gary says tp 5grm are fine for most things I've got over 20 of them but some toys require more speed and accuracy
Re: Maintenance
