electric 3D props Empty2019-07-12, 18:53 by Rich
electric 3D props Empty2019-05-08, 17:49 by Gary M Jones
electric 3D props Empty2019-04-14, 15:36 by Roy
electric 3D props Empty2019-04-13, 16:49 by Roy
electric 3D props Empty2019-03-03, 23:44 by Charles E Cornes
electric 3D props
electric 3D props Empty electric 3D props
Post by Guest on 2009-04-07, 20:11
please....whats the best type of Prop for 3D, e.g Prop Hanging, Coarse pitch/Fine pitch 8
electric 3D props Empty Re: electric 3D props
Post by Andy Sayle on 2009-04-07, 20:29
For 3D type flying you want to aim for a high thrust, and relatively low pitch speed, and that implies using a large diameter, and fine (small) pitch prop, turning relatively slowly.
For a given engine speed (or power) a small diameter/coars pitch prop will give lots of pitch speed, but a low static thrust. A larger diameter/fine pitch prop will give lots of thrust, at the expense of pitch speed. As with all things aeronautical, it is a compromise!
Post by Guest on 2009-04-07, 21:17
thanks Andy regards john
Post by Mark Barnes on 2009-04-08, 09:16
What model is it for John and what are you currently using?
Post by Guest on 2009-04-08, 11:36
Mark...its the Fury and 11x6 thanks john
Post by Mark Barnes on 2009-04-08, 12:36
Ahh ok, from memory then the motor you have the 11x6e is the right prop you could go to a 11x4e but in my experiance of these medium size motors they like the pitch,
So your on the right prop mate
Post by Guest on 2009-04-08, 13:46
thanks guys, appreciate your quick response Smile
