» The gate
Sun Sep 16, 2018 9:53 pm by Rich
» Flying in the grounds of a fantastic Castel
Sun Sep 16, 2018 7:19 pm by BoLt
» Paul Quinn
Mon Sep 10, 2018 7:42 pm by Brian Colclough
» Deganwy Castle
Mon Sep 10, 2018 4:59 pm by Mark Barnes
» Taking flight: the future of drones in the UK
Sun Sep 09, 2018 8:55 pm by Gary M Jones
SU-26 - knife edge coupling....
Post by Andy Sayle on Tue Jun 21, 2011 10:17 am
Morning all,
I got my Wildhare Su26 out from its winter rest yesterday, and had a bit more of a fly. I've tweaked the CG a bit more (although I still think it is a little bit far forward) and it is flying nice now. One thing I noticed though, is that there is a bit of knife edge coupling going on (and I can't remember which way around now!).
When in the knife edge that starts by rolling one way from upright flight, there is very little coupling at all. However, if I roll the other way into knife edge, there is a quite a pronounced nose down couple going on.
Is it normal for this to happen? I was going to have a stab at mixing it out, but doing an asymmetrical mix is going to need a bit more brain power than I have available at the present time....
RDMFC Bonus points : -487569790
Re: SU-26 - knife edge coupling....
Post by Brian Colclough on Tue Jun 21, 2011 10:30 am
Andy I thought you said in our pit chat yesterday that you thought the Suk to be tail heavy ? An assymetrical KE mix shouldn't be too difficult to sort out, need to fly land adjust and fly again till sorted Wink but finalise your C/G first
Post by Rich on Tue Jun 21, 2011 11:58 am
Once you've decided if it's nose or tail heavy & sorted that out, I would try to set the rudder movement so that it will knife edge with the rudder stick at maximum travel, I have found that mixing is required purely because you are using to much rudder, once you've done this you may only require a small mix if any
RDMFC Bonus points : 5600
Post by Andy Sayle on Wed Jun 22, 2011 9:22 am
I've put another couple of ounces of lead on the front end, so I'll see if that results in a perfect CG, and see how it goes from there.
Cheers for the tips Smile
