Jem does PSS
Jem does PSS
Post by Tim on Thu May 05, 2011 10:33 am
Just a couple of snaps of Jem with his LEG "Fish" - watch out for a 200% scaled up version from that man Cocker, who I believe was impressed with it, when Jem had a few flights at the end of the PSSA event on Sunday evening.
Its no good hiding Jem we know its you :-)
Video here of some PSS inflight stuff with a couple of kefob cameras.
http://www.modelflying.co.uk/forums/postings.asp?th=51105#977483
us doing some formation ( well trying too ) flying to finish the event.
My red Hawk, Phil Cooke and Rez Manzoori's Hawks, (Andy Conway design ).
There was a 4th Hawk - but it was sadly lost after tangling with the B52 over the Irish sea, and Simon with the "small" 9ft span B52....of which I now have a copy of the plan Very Happy
Anyone fancy cutting me some BIG foam wing panels Shocked
Nice clips towards the end show just how close I was at times to Phils tail!
Super fun. Very Happy Very Happy
Last edited by Tim on Thu May 05, 2011 10:39 am; edited 3 times in total (Reason for editing : added link)
RDMFC Bonus points : 3227
Re: Jem does PSS
Post by Guest on Thu May 05, 2011 12:00 pm
Tim,
Got a home made bow with max cut of 39''. It runs off my bench power supply 0-30v and up to 5A. You just need the templates and foam.
Re: Jem does PSS
Post by Tim on Thu May 05, 2011 2:40 pm
I already have a bow like that Allan - I dont think this is a job for a normal wire bow.
Re: Jem does PSS
Post by Rich on Thu May 05, 2011 3:56 pm
I can see where your looking then, what is the panel length & cord, is the wing split into several sections
RDMFC Bonus points : 5558
Re: Jem does PSS
Post by Tim on Thu May 05, 2011 4:24 pm
Panel length is approx 1800mm - each panel is one piece
Root Chord = 460mm
Tip Chord = 193mm
( Eppler E205 profile )
Re: Jem does PSS
Post by Andy Sayle on Thu May 05, 2011 4:26 pm
"We're gonna need a bigger Bow"!!!
I'm sure i have seen a film with that line in it.....
In other news, would it be possible to split the wing into multiple panels that will work with your bow, then bond the foam cores together as required?
Re: Jem does PSS
Post by Tim on Thu May 05, 2011 4:29 pm
Well yes thats one way, except I will then need to make up multiple profile templates to suit the chord at the join points.
"were gonna need a bigger boat" Jaws.
Re: Jem does PSS
Post by Tim on Thu May 05, 2011 4:32 pm
I think I should start a new thread in the correct section.
Re: Jem does PSS
Post by Rich on Thu May 05, 2011 4:36 pm
I would to in case it gets Hi-Jacked
My CNC 4 axis foam cutter has a max root cord of about 500, the panel length is in the region of 1000mm if you could split the panel were probably in business, can you send me a pdf of the plan via email I have Profili Pro to set up the wing I'll have a dabble with it
Re: Jem does PSS
Post by Tim on Thu May 05, 2011 4:42 pm
new thread started
Re: Jem does PSS
