»  World Models Piper J3 Cub 48
Today at 10:24 pm by Andyedmead
» Razor Plane Tool
Today at 9:53 am by Andyedmead
» Lots of models and gear for sale
Yesterday at 9:00 pm by Andy Sayle
Yesterday at 8:57 pm by Peter Squire
» Cambria Funfighter P51 Mustang
Tue Jan 16, 2018 9:08 pm by Mark Barnes
#Great Orme 21.12.17
Thu Dec 21, 2017 9:26 pm by Gary M Jones
Good flying this afternoon at the #Orme on this the shortest day of 2017. Wind was bang on the fav. slope probably about 25mph. Must put a ballast bolt in the model. Flight curtailed by the short day length !
My First of 2011
Page 3 of 3 Previous  1, 2, 3
View previous topic View next topic Go down
Re: My First of 2011
Post by Andy Sayle on Tue Mar 29, 2011 11:44 am
I would keep it simple where possible on something that size, less bits to go wrong. Just make sure the parts you use are decent quality, and connected together with decent cables, well supported and neat and tidy.
The only place where I would consider spending a bit of money, or having a redundant setup, is the receiver power supply. Either use a failsafe switch (a solid state one, that can't fail due to vibration, or dirt) or a dual rx pack and two mechanical switches.
As for wanting to use multiple receivers, why bother? You only have one transmitter module/aerial.... The multiple receiver aerials on 2.4GHz rx's do the same thing anyway.
Plus, with less guff onboard, think of the weight savings Smile
RDMFC Bonus points : -487569804
Post by Mark Barnes on Tue Mar 29, 2011 1:06 pm
Not sure on weight and I know what you mean on redudency
As you know weight is key hence my resivations but at the moment to use what Ive got im favouring 1 AR7000 2 2s1p 3300mah rx lipos running through 2 PB Switches
RDMFC Bonus points : 8170
Post by Andy Sayle on Tue Mar 29, 2011 2:39 pm
You could possibly consider using one of the AR9100 receivers instead? It has the failsafe switches, and Dual battery input built in as standard. It would work out rather much cheaper than the two PB switches plus AR7000 too.
Also, for the batteries, two 3300 batts will see you flying pretty much all season off of one charge. You could quite easily have a comfortable afternoons flying on two 2000mAH packs (Or A123 packs if you want to build in some ruggedness, and dare I say it, crashworthyness" to the equipment on board)....
Cheers!
Post by Mark Barnes on Tue Mar 29, 2011 2:44 pm
Andy Sayle wrote:You could possibly consider using one of the AR9100 receivers instead? It has the failsafe switches, and Dual battery input built in as standard. It would work out rather much cheaper than the two PB switches plus AR7000 too.
Cheers!
You obiously missed the part were I said use what I've got lol
If you were there on Sunday you would have overheard a discussion about A123, these may be used if I require weight in the engine box, (Id rather have solid cells attached to that) if there going in the fuse then lipos are the way.
Post by Andy Sayle on Tue Mar 29, 2011 3:13 pm
Ah, just testing......
Don't forget that Lipos bring in the requirement for regulators though (and add another possible failure point to the equation).
I was wondering about coming out to play for a bit on Sunday. Instead, me and Daisy decided to storm Conwy Castle instead....
Post by Rich on Tue Mar 29, 2011 4:53 pm
I'm sure safety is the critical factor when fitting out an airplane that just might go to a show or comp where paying visitors are present, the amount you save in weight is not really an issue with a 50cc petrol model as long as you don't overdo it.
I just happen to have a Gemini & two Lipos ready for my vision when it arrives.
And it's a 58cc engine so power won't be limited.
Just my thoughts
RDMFC Bonus points : 5556
Post by Mark Barnes on Tue Mar 29, 2011 5:18 pm
To be honest Rich thats somthing on my mind, with all the fly-in's I do and hopfully a few comps I want it to be safe (should let somone else fly it then). So dual batts/switches is a minimum.
You're right the 58 should haul ass!
Post by Rich on Tue Mar 29, 2011 6:17 pm
It's quoted as 5.6hp & 1250g DL is 5.5hp & 1350g but neither say what that includes in way of ignition, exhaust etc
Post by Mark Barnes on Tue Mar 29, 2011 6:50 pm
Mine is quoted at
1470g w/ Muffler & Ignition
1250g w/o muffler & Ignition
5.6HP/7500rpm
Post by Mark Barnes on Wed Mar 30, 2011 11:01 pm
A visit to Richies tonight confirmed my RL58 is indeed 1252g w/o and his DL50 is 1350 w/o
Intrestingly the engines share a few similer parts but on a whole there very different. Although bolt spacing look to be the same.
Thanks also for Rich helping me out with the throtle links
View previous topic View next topic Back to top
