New 700 build thread. Empty2019-07-12, 18:53 by Rich
New 700 build thread. Empty2019-05-08, 17:49 by Gary M Jones
New 700 build thread. Empty2019-04-14, 15:36 by Roy
New 700 build thread. Empty2019-04-13, 16:49 by Roy
New 700 build thread. Empty2019-03-03, 23:44 by Charles E Cornes
Page 1 of 2 1, 2  Next
New 700 build thread. Empty New 700 build thread.
Post by Mr Moff on 2010-11-23, 14:39
Well I figured I'd get started on this thread.
I've almost got everything ready to start this build.Just waiting for reciever,2 servos and a couple more upgrades.
New 700 build thread. 700build001
Engine and electronics are,
OS91HZ
Hatori SB20 Mat Botos special pipe.
Spartan Quark gyro
JR 8900 tail servo
JR 8900 throttle servo
JR 8719HV 8 volt cyclic servos
Spektrum 7100R reciever with rev limiter.
Outrage 5000mah reciever pack.
New 700 build thread. 700build004
Upgrades during the build will be,
Quick uk header tank
OS bubbleless clunk
Hayes neoprene clunk line
Quick uk JR servo wheels
Quick uk clutch
RC screws stainless screw kit
RC screws stainless full bearing kit
Quick uk header mount
Align metal elevator servo mount
Micro heli cnc crank sensor mount
Align metal tail control arm
Align metal clutch bearing block
KDE tail upgrade set
Quick uk screw canopy mounts
Micro heli tail boom support brace
RC bearings stainless bearings for the Engine
New 700 build thread. 700build003
New 700 build thread. 700build002
Over the weekend I'm planning on preparing the carbon frames first.
Sanding the edges with some wet and dry 1200 followed by a few coats of some clear nail hardener.This works better than the old ca glue method because it takes longer to dry and it comes with it's own applicator brush.I had to buy my own because my mother says she's mysteriously lost her's. Suspect
New 700 build thread. Empty Re: New 700 build thread.
Post by Andy Sayle on 2010-11-23, 15:12
Ooooh, Pretty!
Post by Mr Moff on 2010-11-23, 23:50
Thank you sir.
I'm still wondering whether to get the dremmel and mirror pollish all the metal.
You can't beat some good old bling bling. Smile
Post by Andy Sayle on 2010-11-24, 09:31
Nah, paint it matt black, the lot of it. Stealth technology is where it is going down next year Wink
Post by Mr Moff on 2010-11-25, 13:40
Black! mat black! that is just so wrong. Shocked
Post by Mr Moff on 2010-11-25, 13:46
Just got a delivery from the friendly postman.A couple more upgrades inching ever closer to starting the build.
The Quick uk clutch.
Lynx titanium frame screw set.These look very nice and even have the Lynx logo etched on the head of each one.I know,I'm sad.
And I finally picked a paint scheme so here's the canopy.
New 700 build thread. Canopy002
New 700 build thread. Canopy001
New 700 build thread. Canopy003
Getting closer. bounce
Post by Stubbsy on 2010-11-25, 15:04
Sweet! - Def need the mirror polish bling to go with that canopy!
Now stop farting about and get building!
Post by Mr Moff on 2010-12-27, 22:21
Finally got started building yesterday morning and everything has gone smoothly so far.
New 700 build thread. 700build009
The head went together very smoothly with no slop or binding anywhere,and all the head links are free with no reaming needed.
New 700 build thread. 700build012
The carbon frames were a little rough around the edges with a couple of areas showing a little de-laminating.Nothing a little wet and dry 1000 wouldn't sort out.
It took about 6 hours to finish sorting out the carbon and after it was all neatly sanded it had many coats of clear nail pollish,followed by some more sanding and a final coat. Suspect
New 700 build thread. 700build016
All the bearings have been swapped out for the stainless set as have all the screws ect.
I swapped out the plastic clutch bearing block for the metal one.The plastic one tends to tweak slightly and tighten the gear mesh on the 600 so that's why that was changed.
New 700 build thread. 700build014
New 700 build thread. 700build015
I just finished mounting the engine into the frames and the quality of the Lynx titanium frame screws is stunning. Cool
New 700 build thread. 700build017
Right it looks like it's coffee break over and time to mount the servo's.(I'm excited about this bit) Very Happy
Post by Zaidy on 2010-12-27, 23:34
Good job Danny.
Just worth mentioning to you that its really hard to change the fuel tubing in the tank if you use the inner hole, you almost have to take most of the frame apart to get to it !! (not impossible)
I used the outer hole on both of my helis as seen on your last photo, it makes life sooooo much easier to service / change the fuel tubes.
Keep it up (the building thread I mean) Suspect
RDMFC Bonus points : 1827
http://Seahawkap.com
Post by Mr Moff on 2010-12-27, 23:53
Thanks Zaide,yes I agree with you about the clunk position.
However my borderline OCD likes things to be equal on each side. Twisted Evil
I just had to get it to reach into each corner the same amount.
When you take the bottom plate off you can get to it from underneath with some fancy finger work. Razz
Post by Mark Barnes on 2010-12-28, 09:29
Nice work Danny, how do you manage to work on that bench with everything to hand. I just cant cope unless I have to spend an hour looking for each tool!
Post by Andy Sayle on 2010-12-28, 11:35
I have a funny feeling that isn't normally a workbench, i think it normally masquerades as a dining room table! Looks good so far though. It will be interesting to see how the stock plastic clutch bearing holder holds up on mine.... I had heard that it was a bit of a weak link, but we'll see.
On the fuel tank, I've had to use both holes for mine (feed and return pipes) and getting the inside one plumbed in neatly without kinks was an utter bottom of a job! Are you planning on running a header tank at all?
Post by Rich on 2010-12-28, 12:57
Nah that fancy patterned stuff looks like something you would have on your bed I reckon, the workbench has to be where he also puts his powder & lipstick on before he goes out.
RDMFC Bonus points : 5639
Post by Zaidy on 2010-12-28, 13:03
That sounds about right, I been there I've seen the lipstick,powder& eye liner. Danny tells me that is normal for a modern guy...! But what do I know
Post by Mr Moff on 2010-12-28, 16:52
Powder and lipstic,you gotta take care of your skin. Very Happy
You're quite correct about the table,too cold to work in the shed at the moment.
The clear lipstic is fantastic for carbon edges,trust me.
Zaides version of lipstic and powder is a leather thong and a pool ball in his mouth. Laughing
Andy I have done the header tank route.
Here's todays build bits.
New 700 build thread. New700build001
New 700 build thread. New700build003
The servo's are in and looking good.I just need to power them up and centre them once the links are in place.
New 700 build thread. New700build007
I took a couple of pictures with the canopy on just to see how it looks.
New 700 build thread. New700build009
Tomorrow I'm hoping to get all the links setup and then the reciever done.Then it's time for the boom,woohoo. bounce
Post by Rich on 2010-12-28, 21:46
As much as I don't do Helicopters, that looks the dogs B*****KS, very professional
Post by Mr Moff on 2010-12-29, 01:59
Thanks Rich,I just hope it flies as well as it looks.
Fingers crossed. Very Happy
Post by melfyn on 2010-12-29, 12:20
I do like the Torro blingy servos. Are they ally cased?
Post by Stubbsy on 2010-12-29, 17:37
2 am posts! Good going there Danny!
Post by Mr Moff on 2010-12-29, 19:00
Yes Mell,alloy cases,titanium helical cut gears and brushless motors.
Outrage Torq BL9080 is their full name.Apparently they're making a mini version as well in the near future.
Andy I forgot to mention,don't worry about the plastic clutch bearing block.It works perfectly fine.The only reason I had to replace it on the 600 is because mine needed the bearings changed quite regularly,and after removing it a few times it became a bit sloppy.
Welcome back Stubbsy,I was wondering when you would be able to plow your way back through the snow. Cool
There's not much progress been made today.Just lot's of link building and a quick wire run to make sure all the wires reach the reciever.
New 700 build thread. New700n001
Everything does reach but the on/off switch is much smaller than the hole provided so I need to modify the plate or use another location.
Also the rev limiter sensor and the push glo pro wires need routing so that they don't obstruct the removal of the engine.I like to be able to drop the engine easily without disturbing the wiring.
Looks like it's time for a brew and a thinking session.
Post by melfyn on 2010-12-29, 23:00
Or get one that does fit.
Post by Mr Moff on 2010-12-30, 00:23
It's a strange one because it's a fail on soft switch that comes with the 7100R receiver.
I'm looking at it now and maybe thinking of using hot glue under the bottom of the frame.
Then maybe use a small Velcro strap to give a little extra support.
Maybe.
Post by Rich on 2010-12-30, 08:41
PM sent
Post by Mr Moff on 2010-12-31, 17:59
A little more done this afternoon.
I wasn't exactly sure about what the benefits were to using the KDE tail upgrade,but there is 2 advantages.
First is an extra radial bearing on each tail blade grip after the thrust bearing.
New 700 build thread. 700tail001
This now sandwiches the thrust bearing between 2 ballraces.
The second is the double joint arms that normally articulate using 2 bushes.
New 700 build thread. 700tail002
New 700 build thread. 700tail004
The double joints are now metal and articulate on 2 flanged bearings.
The other change I've made on the tail is to ditch the plastic tail pitch control arm for the metal one.
New 700 build thread. 700tail005
This makes for a super smooth tail with no slop anywhere.
New 700 build thread. 700tail006
I also powered up the servos to centre them and they are super fast and quiet.
I'm a bit surprised with how loud the JR8917 HV is on throttle.I thought someone had parked an Astra diesel in the living room and left it ticking over. Laughing
Looks like it's time to pour the JD and coke.
Post by Mr Moff on 2011-01-04, 17:13
I managed to get more done today with some more photos.
There's a couple of notes worth checking on all 700 kit's.
One thing I noticed was the elevator bellcrank had a lot of side to side play.It was enough to allow the anti rotation bracket to twist by about 5mm.I think with this amount of play it could allow a small amount of interaction when the swash is tillted at the extreme of it's throw.
What I did was I put 2 shims of 0.2mm on there.One on each side which now leaves minimal play and it still has full freedom of movement.On page 16 in the manual I've illustrated where they went.
It's also worth sorting out the bellcrank and tightening up the ends before tightening up the set screw in the centre of the anti rotation bracket.This will allow it to all be centred before locking the bracket down.
New 700 build thread. 700finished010
For anyone using the Hatori sb20 pipe it is best to assemble it and fit it before putting the engine in the frames.
The other thing worth noting is that on page 18 if you look at the top illustration you will see the long umberella gear.There is 2 bearings on it and the one nearest to the gears teeth could do with a little ca glue and then pushing it all the way on firmly to prevent the mesh from tightening and possibly stripping a gear.
The transmitter values so far are,(for JR sets,Futaba may be different)
Channels reversed ch3,throttle,rudder and ch6
Endpoints for the throttle are H 102% and L 96%
Servo horn distance on the throttle are 14mm out and 13mm out on the carb.
When using the rev limiter it is important to get the throttle end points as close to 100% as possible,which requires messing round with different servo horns untill you get them to within 10% of each other and both close to 100%.This is why I've noted the distance out I ended up with on the servo horn.
Tail servo wise I ended up with 14mm out which should give a good compromise between torque and speed.
Something else worth a mention is that on JR sets with the 7100R reciever to use the governor menu for headspeed you need to go into the devise select menu and enable the gear output to read "GOV".What this does is it uses the gear channel as the gov menu.
Now you need to go to "AUX2" and change it to "GYR".
Next make sure you plug the gear lead on your gyro to the "AUX2" on the reciever.
What you end up with here is the gov menu now picks your headspeed and the gyro sets your gain on the gyro.
New 700 build thread. 700finished008
New 700 build thread. 700finished004
New 700 build thread. 700finished006
New 700 build thread. 700finished002
Next I'll get all the final setup done and I'll post the lengths I end up with on the links and I'll post the rest of the tranny settings.
