EPP shaping Empty2019-05-08, 17:49 by Gary M Jones
EPP shaping Empty2019-04-14, 15:36 by Roy
EPP shaping Empty2019-04-13, 16:49 by Roy
EPP shaping Empty2019-03-03, 23:44 by Charles E Cornes
EPP shaping Empty2019-02-10, 16:31 by melfyn
EPP shaping
EPP shaping Empty EPP shaping
Post by Marty on 2010-10-05, 21:55
Dunno if this is the right section? if not would one of the admin bod's move it?
Ok, what I'd like to know is, has anyone tried using a router on EPP foam? I wanna make some recesses in a foam block on a secret project, I'm not sure if the foam will take it or just disintergrate.
EPP shaping Empty Re: EPP shaping
Post by Rich on 2010-10-05, 22:01
It will take it use, permagrit drum sanders, it does make a bit of dust so either have the vaccum running close to it, I use them when I cut servo boxes or hinge lines in wings just use something to stop it going right through. I you need help give me a call
My router is attached to a CNC gantry router bed
http://www.permagrit.com/index.php?cPath=68&osCsid=s1mk6p4nk9mfd1v6rgahpj4b47
RDMFC Bonus points : 5636
Post by Marty on 2010-10-05, 22:48
Those look just the ticket, just need to check the size of the shafts in my router.
Thanks for that Rich.
Post by Rich on 2010-10-07, 10:07
most router have a 3.17mm adapter if you need to borrow one give me a call
Post by Andy Sayle on 2010-10-07, 10:10
If you are shaping manually by hand, the coarse Permagrit files work well too. The dust gets EVERYWHERE, and sticks to everything too. Just the ticket for pretending it is snowing outside Smile
By the way Rich, on your CNC gantry, what type of bearings have you got on there? (the ones for the X, Y and Z carriages/gantry)?
Post by Rich on 2010-10-07, 10:12
some for of standard parallel bearing running on 25mm steel shafts
Post by Andy Sayle on 2010-10-07, 10:15
Ah, gotcha, a linear ball bushing. I couldn't remember if it used carriages made from normal ballraces acting on a bit of angle iron or not...
Post by Rich on 2010-10-07, 10:22
no not like that see email
Post by Andy Sayle on 2010-10-07, 10:55
Ah, I see. Clever Smile
Post by Marty on 2010-10-07, 11:06
Thanks again Rich, I'm busy trying to get a helmet out before the weekend.
This Secret Project is not pressing at the moment, I'm in the exploritory stages .. you know ... measure twice, cut twice and it's still too short! lol
I'll see ya tonite?
Post by Rich on 2010-10-07, 13:24
Marty wrote:Thanks again Rich, I'm busy trying to get a helmet out before the weekend.
I'll see ya tonite?
not unless your in Great Yarmouth you won't
Post by Andy Sayle on 2010-10-07, 13:32
Marty wrote:I'm busy trying to get a helmet out before the weekend.
There are so many jokes in that there statement! Twisted Evil
Post by Marty on 2010-10-07, 13:48
Only YOU! Suspect
Anyone ever tell you that you have a warped mind? PMSL
