» St Asaph ?
Today at 1:08 am by Allan Patrick
» Changes to UK regulations from 30.7.18
Fri Jul 27, 2018 3:58 pm by BoLt
» Orme monday evening
Sun Jul 22, 2018 7:47 pm by jem matthews
» LLanfair TH Village Fete Saturday 28th July 1030
Mon Jul 16, 2018 8:11 am by Mark Barnes
» SC engines?
Sun Jul 15, 2018 6:07 pm by Gary M Jones
1 0 1 0 0 1 1 0 1 1
Page 2 of 4 Previous  1, 2, 3, 4  Next
Re: 1 0 1 0 0 1 1 0 1 1
Post by Mark Barnes on Sun Jan 16, 2011 4:00 pm
get yours done then!
RDMFC Bonus points : 8228
Post by Rich on Sun Jan 16, 2011 4:49 pm
Waiting on a regulator
Also noticed that the build thread is for R/E only so may take a little more time.
Last edited by Rich on Sun Jan 16, 2011 8:39 pm; edited 2 times in total (Reason for editing : SPELLING)
RDMFC Bonus points : 5597
Post by Andy Sayle on Sun Jan 16, 2011 7:04 pm
Did someone call?! Smile
Actually Barnes, just got the finishing touches to do now.... Just faced the aileron/wing cut edges with some epoxy/microballon slurry. Can't have the wings and surfaces being all floppy now can we?
And anyway, it seems having a baby does eat into "toy time" somewhat more than I expected......
RDMFC Bonus points : -487569790
Post by Roy on Sun Jan 16, 2011 7:21 pm
Andy Sayle wrote:Did someone call?! Smile
Did the 700 get in the way of the glider Twisted Evil
Royb
RDMFC Bonus points : 699
Post by Andy Sayle on Sun Jan 16, 2011 8:41 pm
Un Peu.....
Post by Mark Barnes on Mon Jan 17, 2011 6:39 pm
Ahh good man, told you the little one would be trouble! To be honest looking at the state of my hanger there isnt any room for it anyway
Post by Guest on Mon Jan 17, 2011 10:38 pm
damn does this mean i have to build mine now affraid
Post by Rich on Mon Jan 17, 2011 11:07 pm
No because you isn't the light weight one
Post by Mark Barnes on Tue Jan 18, 2011 9:10 am
Yeah dont bother Gaz, yours will be heavy and glide like a brick
Post by Guest on Tue Jan 18, 2011 9:50 am
We shall see Basketball
Post by Roy on Mon Jan 24, 2011 5:31 pm
Model now at Hobby King.
Roy.
Post by Mark Barnes on Mon Jan 24, 2011 6:39 pm
Ahh thats what they look like
Post by Andy Sayle on Mon Jan 24, 2011 6:57 pm
They are about 30 dollars cheaper if you go direct to peak hobby.....
Post by Andy Sayle on Sun May 22, 2011 7:36 pm
Rumour has it that Barnesys binary is ready for action....
Post by Mark Barnes on Sun May 22, 2011 8:19 pm
WHOOOOOOOO HOOOOOOOOO
Must be a bugger to build, 6 bloody months!
Post by Roy on Sun May 22, 2011 8:25 pm
Looks like Andys finished it too early looking at the wind forcast for next week Twisted Evil
Post by Andy Sayle on Sun May 22, 2011 8:38 pm
I'll be honest, it's not the nicest model to build, it better bloomin fly nice! The weather forecast is a little sinister too....
Post by Guest on Sun May 22, 2011 9:06 pm
havin probs with mine aswell Crying or Very sad thought it should be ready midweek Very Happy
Post by Marty on Sun May 22, 2011 9:45 pm
Mine is has proved to be a............. challenge!
Post by Andy Sayle on Mon May 23, 2011 6:38 am
Stick with it Marty, this one doesn't have a throttle Wink
Post by Rich on Mon May 23, 2011 8:35 am
Very low
Post by Marty on Mon May 23, 2011 8:58 am
LOL. Did you have to use extention leads for the servos?
Post by Andy Sayle on Mon May 23, 2011 9:31 am
Er, sort of, yes. I actually cut the plugs off the end of the wing servos, threaded the wires under the skin to the centre (I used a bit of hot wire to cut a small channel in the foam, about 3mm dia, just under the glass skin). I brought them out in the middle, about 1" aft of the front two wing bolt locations. I then fitted a 4 pin Ashlok connector to the exposed wires. I then made a small harness with the female half of the ashlok connector, with two wires long enough to reach the pod where ther rx was, and this was terminated in normal servo connectors.
I did this so the wing could easily be removed (if needed). There is no reason why the extensions cannot be hardwired though, The model is small enough to leave in one piece really....
Post by Marty on Mon May 23, 2011 9:56 am
I remember you telling me but taking off of plugs scared me coz the the leads are so titchy! I don't like playing with 'lectric magic at the best of times.
I was reading somewhere that the binary does like a little weight but I probably have used uo any leeway with glue wieght!
Post by Andy Sayle on Mon May 23, 2011 10:05 am
The little DLGs like these are never going to be lightweight floaters, there is just too much structure to support with not enough wing area. For that reason it is better to build them a bit stronger to withstand some abuse, and have some fun with them. The Binary is a cracking example of one of them too. There is just too much weight in the foam cored wings, beefy carbon boom, glass pod etc, to make it a really efficient little thermal soarer. So, don't worry too much about extra weight, and accept the fact it will be a cracking little light wind slope model, or it will give you some serious exercise on the flat field!
The leads are pretty small, yes. What you could do, is just leave them intact, and use some normal servo extensions. You would probably only need about 4 inch long ones. That way you have a join near the wing too, perfect for a removable wing Smile You can either hide the wires from the servos to the wing root under a bit of tape, or cut a slot into the wing to "chase" the wires in to hide them.
