» July full weekend
Yesterday at 10:21 pm by Rich
» Beasts
Yesterday at 10:06 am by Rich
» Wanted HS85MG or Similar Spec X4
Thu Jun 21, 2018 3:22 pm by Andyedmead
» Weston 2018
Wed Jun 20, 2018 12:58 pm by BoLt
» Weston Park 2018
Tue Jun 19, 2018 7:59 pm by BoLt
Landinggggggg
Comments: 6
Replacing crank shaft washer
Post by Stubbsy on Tue Aug 17, 2010 10:43 am
Ok, not sure if this is where I need to post this but need some advice from you experts!
Putting on a new nose cone to my MDS40 and find that with the prop, nose cone and domed washer, there is very little thread left on the crank shaft to screw the holding nut onto. The domed washer which holds the prop to the back plate is about 5mm thick which seems very exessive to me. I just want to know if there would be any issues in swapping the domed washer for a sturdy flat washer, and the nut, to a locking nut?
ie in order it would be - plane, back plate, prop, nose cone, washer, lock nut
Doing this would give me a bit more crank shaft thread to play with and I would be much happier with the fit!
Cheers all Very Happy
Ben......
Re: Replacing crank shaft washer
Post by Stubbsy on Tue Aug 17, 2010 10:55 am
Ok, don't shout, just seen this should have probably gone in the 'engine' forum! Sorry!
Post by Roy on Tue Aug 17, 2010 11:18 am
Yes that will be fine just make sure the the washer is the same size just
to spread the load.
RDMFC Bonus points : 699
