no lift??
Page 1 of 2 1, 2  Next
no lift??
Post by colin on Tue Jun 01, 2010 6:25 pm
hi guys
well have finished all repairs to 450 heli but now it wont lift off?? any ideas
Colin
colin
RDMFC Bonus points : 59
Re: no lift??
Post by Mark Barnes on Tue Jun 01, 2010 6:26 pm
First guess would be pitch curve Colin, is it going into poss pitch?
RDMFC Bonus points : 8185
Re: no lift??
Post by colin on Wed Jun 02, 2010 12:00 am
I dont know quite what you mean mark, it spool up but just sits there !!
Colin
colin
Re: no lift??
Post by Zaidy on Wed Jun 02, 2010 6:04 am
check you pitch range, using a pitch gauge and as mark said first, ie adjusting the curve to suit.
-2 at zero stick
5 at mid stick
8 at max stick
remember to disconnect the speed motor when you do this. if you pitch range
RDMFC Bonus points : 1827
http://Seahawkap.com
Re: no lift??
Post by Rich on Wed Jun 02, 2010 7:53 am
just be careful colin in case it's in neg pitch does it push itself into the ground when you throttle up & lift slightly when you throttle down if it does you may have the pitch reversed, failing that can you see the blades moving when you open the throttle with no motor on the trailing edges of the blades should move down for pos pitch & up for neg pitch
RDMFC Bonus points : 5558
Re: no lift??
Post by Zaidy on Wed Jun 02, 2010 8:31 am
sorry about the broken email ! was trying to do too many things in one!
if you still have a problem Colin, bring it to the field, will have a look at it for you. Should be there from Friday weather permitting.
Re: no lift??
Post by Brian Colclough on Wed Jun 02, 2010 8:33 am
Most important words in all of the above are be careful. If you're unsure get someone else with more experience to suss it out for you Colin Wink As per Zaidy's offer
Re: no lift??
Post by colin on Wed Jun 02, 2010 9:08 am
ok all
l will check pitch first, without motor plugged in.
c
colin
Re: no lift??
Post by Rich on Wed Jun 02, 2010 9:10 am
Zaidy wrote:sorry about the broken email ! was trying to do too many things in one!
OH NO..!!!
Re: no lift??
Post by Andy Sayle on Wed Jun 02, 2010 9:16 am
I was wondering if he had been kicked out of his own home, and is being forced to seek refuge at the field!
Re: no lift??
Post by Rich on Wed Jun 02, 2010 9:20 am
he has to make up for the lost time, it will be nice to see him occasionally
Re: no lift??
Post by Andy Sayle on Wed Jun 02, 2010 10:00 am
Perhaps we should consider painting some parking spots in the pits, and have one especially reserved for Zaidy?
Re: no lift??
Post by Zaidy on Wed Jun 02, 2010 11:09 am
LMAO.. You are right Rich, I have to make up for lost time, which wouldn't take very long !! 7 days of 10am till late ish should do it !
Andy, I think that parking spot idea is a great one.
See soon
Re: no lift??
Post by Rich on Wed Jun 02, 2010 11:42 am
trouble with the parking lots there all taken, it's the long grass for you matey
Re: no lift??
Post by Zaidy on Wed Jun 02, 2010 11:48 am
Rich wrote:trouble with the parking lots there all taken, it's the long grass for you matey
Oh I see.
I guess you wouldn't mind if I use yours during the week then Razz while you you are busy at work Suspect
Re: no lift??
Post by Mark Barnes on Wed Jun 02, 2010 11:51 am
I love the way this has stayed on topic to help Colin out lol,
Re: no lift??
Post by Sam Thomas on Wed Jun 02, 2010 12:28 pm
Yeah!
lol
Im pretty sure zaidy could help you out Very Happy
Sam Thomas
RDMFC Bonus points : 1962
http://www.youtube.com/user/popcornreviews
Re: no lift??
Post by Rich on Wed Jun 02, 2010 9:53 pm
I'm away for a coulpe of weeks soon, however you are welcome to the short grass spaces until the real flyers arrive as you would of flown out by then
Re: no lift??
Post by Zaidy on Fri Jun 04, 2010 7:01 am
Thanks Rich, that will do as a start and I will consider handing the space back when you come back from you holidays.
Very Happy
Re: no lift??
Post by colin on Fri Jun 04, 2010 11:34 am
Ok checked with pitch gauge
-12 at bottom stick
-6 at mid stick
=1 at top stick
so if I alter my linkages for one setting, how do I set each one
c
ps this is in normal mode
colin
Re: no lift??
Post by Rich on Fri Jun 04, 2010 12:57 pm
the minus 6 at mid stick is incorrect, not 100% but it needs to be positive pitch check you manual.
You'll have to use the transmitters end point adjustment & pitch curves if it has them
Re: no lift??
Post by Mark Barnes on Fri Jun 04, 2010 1:04 pm
there all way out -12 will just slam the heli into the deck if you drop the throttle stick
As Zaid says for normal -2 +5 +8
Heli will proberbly be capable of -12 to +12, use a pich curve in the TX along with you pitch gadge to alter, you may have 3 points or 5 depending on TX
Re: no lift??
Post by Zaidy on Fri Jun 04, 2010 2:02 pm
Right that is way out!
Start with
check servos are @90 deg to links (under power)
then
check your links are the correct length as per manual
so the end results
swash plate is level at mid stick
then you play with you pitch curves on your tx.
Ps for ccpm to work correctly, all three servos have to be the same
I hope this helps
Re: no lift??
Post by colin on Fri Jun 04, 2010 6:44 pm
hi Zaidy
all three servos are 90 at mid stick and all new Tunigy's TG9e
servo rods spot on
links rods spot on
swash spot on
VRB knob at 12 o'clock
should throttle trim be at zero or centered? on tx
I have 5 points on my pitch curve ( in % ) they are
ep0 38%
1 54%
2 70%
3 85%
4 100%
colin
colin
Re: no lift??
Post by Rich on Fri Jun 04, 2010 6:54 pm
throttle stick & trims mid point as they are linked together electronically
Re: no lift??
