The Mighty Cherub Empty2019-07-12, 18:53 by Rich
The Mighty Cherub Empty2019-05-08, 17:49 by Gary M Jones
The Mighty Cherub Empty2019-04-14, 15:36 by Roy
The Mighty Cherub Empty2019-04-13, 16:49 by Roy
The Mighty Cherub Empty2019-03-03, 23:44 by Charles E Cornes
The Mighty Cherub
The Mighty Cherub Empty The Mighty Cherub
Post by Mark Barnes on 2010-05-19, 20:06
Little vid of the Cherub, worth watching if only for the clips of Jem at the end
The Mighty Cherub Empty Re: The Mighty Cherub
Post by Tim on 2010-05-20, 08:09
Looks nice that, and great VFM - is it KIT ARTF RTF or what ?
Post by Mark Barnes on 2010-05-20, 08:41
ARTF Tim, supplyed with a brushed 400, all the linkages etc etc, built in one evening, All ive had to add is 2 servos (specktrum 7.5grm) a ESC 20amp, Lipo 3s1p 2200 (although i think 2s 1500mah would suit it better) prop and RX
I do have a brushless motor to go in it but to be honest i dont see the point, with the 2200`s ive had 18mins of motor run and only used 52% of the battery, although 3s on a brushed 400 is gonna burn it up pretty quick
Post by Robert Piechulski on 2010-05-20, 09:05
Some time ago I used to fly my EG with 3S1P 800 mah lipo (with 3f motor) - just didn't want to land - enough power to have 2-3 lifts (after 2 my neck was refusing to co op Laughing )
So I believe it will work nice in here as well (question is about CG if 800 lipo will CG'd it)
Robert Piechulski
Robert Piechulski
RDMFC Bonus points : 583
Post by Mark Barnes on 2010-05-20, 09:10
To be honest there is loads of room in the fus to move things about Rob, so im sure you could get it to balance just fine, mine is nose heavy at the mo, so a smaller pack would help alot, then if you move the RX forward (mines right on the servos at the back of the wing) balance will be fine i reckon
Post by Robert Piechulski on 2010-05-20, 09:23
If you find some time - would you make few pics of the inside please ?
If it only had ailerons - I'd take it straight away Smile
Robert Piechulski
Robert Piechulski
