Spring Fun Weekend - May 29/30th
Page 2 of 2 Previous  1, 2
Re: Spring Fun Weekend - May 29/30th
Post by Sam Thomas on Sat May 29, 2010 9:53 pm
Hmmmmm...
You have got me thiking here... possibly something off nain and taid for my B-day?
What sort of airbrushes should I be looking at as a first one?
Nothing OTT frills, but does the job well
Sam Thomas
RDMFC Bonus points : 1962
http://www.youtube.com/user/popcornreviews
Post by Andy Sayle on Sat May 29, 2010 10:21 pm
As with most things, the more you spend, the better the tool! I would recommend a double action airbrush (seperate air and paint control on the trigger) as they are much nicer to use, and give you more control over the paint you are putting down.
I would also recommend one that can accept different size paint reservoirs. Some of them just have little thimbles, which are great for fine detail, but rubbish if you want to cover a larger area quickly.
I've got an Iwata Eclipse SBS, but that wasn't particularly cheap. That has a side feed, so it can accept gravity feed cups/thimbles, or larger suction feed reservoirs.
Post by Sam Thomas on Sat May 29, 2010 10:21 pm
Would this do?
CLICKY
and this for a regulator CLICKY
I really would like to have something similar to this on one of my cars Smile
http://thetoyz.com/forums/index.php?showtopic=14291
Sam Thomas
Post by Andy Sayle on Sat May 29, 2010 10:36 pm
That airbrush looks pretty good for the money, although a 0.2mm needle/nozzle is a bit on the small size. I normally use a 0.5mm needle, or a 0.35mm for really fine stuff. The smaller the needle, the more difficult it is to cover large areas, so if you only want to do detail work, then a small needle is fine.
Also, that brush has a fixed size reservoir, which you might find to be a bit of a pain (I would!)
Post by Sam Thomas on Sat May 29, 2010 10:46 pm
So this is really what Im looking for clicky
Where could I find a suitable pressure regulator?
Do you have any traps/filters in your lines?
Sam Thomas
Post by Mark Barnes on Sat May 29, 2010 11:24 pm
Fair doo`s that TX looks loads better than the last one,
However its soon to be surpased by my TX Case thats going to Marty on Monday for some "bang on trend" BB Bling
RDMFC Bonus points : 8185
Post by Andy Sayle on Sun May 30, 2010 12:09 am
I've still not mastered the art of clear coating, and I think the paint I am using is a bit rubbish, it is an absolute mare getting it thinned right. Too thick and it is all sputtery, too thin and it goes on too dry. Methinks it is time to ditch the pactra paints, and switch to something waterbased..... Can't wait to see what you have put on your Tx case. Speaking of which, I've just cut the foam out on my new one Smile
Sam, I've got a regulator that is built into my compressor, and then one on the brush itself that is abit like this. I keep meaning to get something posher that has a finer control, but this does me for now.
Post by Marty on Sun May 30, 2010 5:07 am
Andy, did you pinstripe the black out line on the jet?
Sam, When I first started with the airbrush I made the mistake of buying cheap ..... BIG mistake! I now use IWATA .... but there are loads of good makes out there and people tend to stick with a make thay are comfortable with.
I could bore everyone to death on this subject ......
Big compressor's are fine (in fact they are desired) providing, as Andy says, you use a regulator. With my 0.5 I tend to use about 40psi and reduce it to anywhere between 14 - 30 psi for my 0.35. you will need a a moisture trap / filter, and you need to be carfull of the type of compressor, some have a facility to feed oil into the air for lubricating tools .... avoid these at all cost!
Might be woth you joining a forum......
Post by Andy Sayle on Tue Jun 01, 2010 10:01 am
Pinstriping, that's the one. Well, if I rename my permanent black marker pen, and call it my jet black pinstriping pen.....
Cheers for the advice yesteday Marty, much appreciated Smile
Post by Marty on Tue Jun 01, 2010 11:21 am
Andy, it was good to meet you at long last! I was beginning to think you were a dummy figure head ..... (leaves loadsa room for Mark to pick up on that )
PMSL at jet black pinstriping pen lol, but it does the trick
And no worries about the advice. Any time I can help I will, and that goes for anyone in the Club. (goes without saying really).
