Which oils?
Which oils?
Evening all.
I was just wondering if there are any particular types of 2 stroke oils that are recommended for running in, and subsequently normal operation of, a dle55 petrol engine? I need to buy some fairly soon you see.
Also, what sort of mix ratios are the best to go for?
Re: Which oils?
Andy I use Stihl 2 stroke oil as I use the same mix for my models as my strimmer and chain saws. My ZDZ's like 40:1 mix which gives a better seal on the rear disc valve which is peculiar to the ZDZ . Most guys running DA's and DL's ron 50:1 mix. I run my motors in on the same stuff I use normally but some run their engines in on a non-synthetic ashless oil for a couple of gallons saying that this speeds up the running in process ? You'll get as many opinions as people you ask, it's much like the Futaba or JR/Spektrum question it'll rumble on forever
Re: Which oils?
Roto recommended Motul 710 synthetic for my roto 25 in 2007
Motul changed that to 800 2T Factory Line Off Road
100% Synthetic
They say
"Maximum power and protection
800 2T Off Road was developed for the leading factory teams to ensure maximum engine performance. Formulated using anti-emulsification agents to prevent throttle valve jamming. Pre-mix lubrication only."
Stocked at Jonesies Motorcycles Kinmel bay just near the railway bridge opposite to road to Asda
50/1 mix grade 95 unleaded.
Just a comment here, PAW always recommend increasing oil to fuel ratio particularly with smaller engines. Simply because there is more sliding surfaces in contact per cc in a small engine (model) compared with full size (motorcycle)
100% Synthetic
They say
Last edited by PDQ on 2010-05-09, 20:29; edited 1 time in total (Reason for editing : added paw comment)
Re: Which oils?
Speaking from the motor bike side, IMHO, which ever type you start with you should stick with.
I wrecked a bike engine for the sake of a few quid when I put in some oil that was a different type (but had loads spare!).
BTW, I don't know the mechanics of the engine you're talking about but full synthetic can produce clutch slip in some brands of motor bike with wet clutches,
Re: Which oils?
Love your honesty Sam, that's made me chuckle!
Cheers for the input too guys, much appreciated. I've been doing a bit of reading, including the DA50 manual (which is excellent!). Apparently it makes sense to run a semi-synthetic oil at 30:1 ish for the first couple of gallons, and a prop that allows the engine to rev freely (so slightly less diameter), so that the piston rings bed in nicely. After that, switch to a synthetic oil, at a mix ratio of about 50:1.
Methinks a trip down to Woods in Abergele on the way home is called for
Re: Which oils?
Watch out for the tree huggers!Methinks a trip down to Woods in Abergele on the way home is called for
Re: Which oils?
I've tried a few different ones but these are for zenoah g260's and CY's but I've settled on using Rock oil semi synth from king cobra.
Valvolene is another good one but I preffer rock.
Mixture is normally 25:1 but I've always used 33:1 which translates to 150ml oil to 5 litres fuel.
I always use v power for 99 octane,well worth the extra few pennies.
Re: Which oils?
melfyn wrote:Watch out for the tree huggers!Methinks a trip down to Woods in Abergele on the way home is called for
thats funny Mel
